Brake calipers won’t bleed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oliaslaughlin, Mar 10, 2022.
  1. Mar 10, 2022 at 11:36 AM
    Oliaslaughlin
    Oliaslaughlin [OP] Active Member
    Olias
    2000 tacoma trd 3.4l 4x4
    Toytec coilovers on 33s
    Hey y’all I recently got some S13WE calipers from a first generation tundra for my 2000 Tacoma. My truck previously had these same calipers previously and I never had any issues until one started sticking. When I ordered my new calipers, I was sent one faulty caliper that had bad threads on it and I sent it back and got a replacement. I now have the two calipers on the truck, but I’m having issues bleeding them out. I wasn’t able to bleed them or the master cylinder thoroughly so I took it to Les Schwab tires and had their brake department look it over. Their break department said that they weren’t able to get the pedal to feel any better and it kept going to the floor. They think that I have faulty calipers. Is it really realistic that these would be faulty or do you think there’s an issue with the bleeding? I have another set of calipers from O’Reilly‘s that I’m gonna throw on just a check if it is the calipers that are currently on the truck. However if it’s just something with bleeding, that I wasn’t able to do and Les Schwab wasn’t able to do correctly, I would love to try to figure that out before changing calipers again. Thanks in advance!
  2. Mar 10, 2022 at 11:53 AM
    Roberto123
    Roberto123 Well-Known Member
    robert
    2018 Tarcoma SR 4X4 Dbl Cab
    Hook your peepers on the banjo bolts. Are you using the Taco banjo's with the Tundra brakes? Not sure if they mesh well. Just my 2 cents.
  3. Mar 10, 2022 at 11:55 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Get yourself a motiv power bleeder (if you don't already). They are worth every penny. I trust you are bleeding the entire system (starting at the back)? It would seem unlikely that the calipers would be bad. Did the master cylinder ever empty while you were replacing them?
    Shamal likes this.
  4. Mar 10, 2022 at 11:55 AM
    Oliaslaughlin
    Olias
    Not a banjo bolt style, using the tundra brake lines with flare nut.
    Roberto123 likes this.
  5. Mar 10, 2022 at 11:56 AM
    Oliaslaughlin
    Olias
    Master cylinder did empty. Les shwab bled back to front and the master twice.
  6. Mar 10, 2022 at 11:59 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    My money would be on a damaged master cylinder before the calipers. But I'd still get the motiv power bleeder and a gallon of brake fluid and have a go with that before you write it off.
    And I think you can get master cylinder rebuild kits, which would be better if you still have the OEM cylinder.
  7. Mar 10, 2022 at 12:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you have ABS, that's the place keeping air.
    You either need Techstream software to safely bleed (to activate the ABS) or someone who is willing to do some hoonagin bleeding.
    Badknees likes this.
  8. Mar 10, 2022 at 12:14 PM
    Oliaslaughlin
    Olias
    Interesting, I didn't think about the ABS I'll look into that.
  9. Mar 10, 2022 at 12:17 PM
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    THIS^^^
    I had the exact same issue when I installed the Tundra brake upgrade on my '98 with ABS. Had to take it to the Toyota shop to get it right. Best.
  10. Mar 10, 2022 at 12:21 PM
    Oliaslaughlin
    Olias
    Thank you all, I've been chasing this for weeks and need my truck back. I appreciate the help.
    Clearwater Bill and Badknees like this.
  11. Mar 10, 2022 at 12:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    IF I'm right, that's an indicator that Less Slob may not be the hot ticket for brake work. o_O
    If I'm not right, at least I didn't charge anything. :D
    Kevins60 likes this.
  12. Mar 10, 2022 at 12:23 PM
    Badknees
    Kenny
    Anderson, SC
    Seems there is a procedure floating around somewhere for bleeding with ABS brakes, so it might help if you find it and have the right tools. For me, it was just easier to drop it off and let the Toyota shop do it.
  13. Mar 10, 2022 at 12:25 PM
    Oliaslaughlin
    Olias
    Yes, I've always been wary of Les Schwab. I'll see what I can do otherwise it will need to be towed to Toyota.
  14. Mar 10, 2022 at 12:28 PM
    Badknees
    Kenny
    Anderson, SC
    Think I found it...
    EDIT: I'm too old and forgot I had the same problem on my '02 4Runner, which this procedure was written for. I think similar principles apply though to the 1st Gen. Tacomas with ABS brakes.
  15. Mar 10, 2022 at 12:35 PM
    Oliaslaughlin
    Olias
    Perfect thank you, probably going to need Toyota to do it.
  16. Mar 10, 2022 at 6:22 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    I'm sure you've checked this already, but make sure your calipers aren't mounted on the wrong side. Bleeder screws need to face up! Sometimes simple stuff like this gets overlooked.
  17. Mar 10, 2022 at 8:29 PM
    Oliaslaughlin
    Olias
    Thanks, man. Yes, they are facing up and on the correct side. Always good to check though, definitely made dumb mistakes like that before.
  18. Mar 11, 2022 at 3:16 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Are you saying the air is trapped in the ABS system because the MC went dry? Reason I’m asking is that I just replaced my front and rear brake hoses and made sure the MC never got close to MIN when I bled RR, LR, RF, LF and LSPV in that order. You have me wondering if I jacked up my ABS.
  19. Mar 11, 2022 at 3:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. It's a common problem when the MC has to be replaced, which is about the same as going dry when bleeding.
    If ABS is a problem fluid wise you'll know right away, because the pedal will feel soft like you need to bleed the system.
  20. Mar 11, 2022 at 3:30 PM
    Kevins60
    Kevin
    Odessa FL
    Pedal feels the same as it did before I did the hoses and it doesn’t pump up like it still has air in the system but I always thought the pedal felt soft. I’ll ask my neighbor if I can drive her ‘98 around the block for comparison.
