Brake Calipers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bldegle2, May 28, 2024.
  1. May 28, 2024 at 7:07 AM
    bldegle2
    bldegle2 [OP] OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Quick note. Had alignment checked several times, spot on. Truck always wants to go slightly left on its own. All suspension components in good order.
    It concerned me.
    Changed front rotors and pads, drivers side worn out, passenger side still had 5 to 10,000 left on the pads (not much, but still viable). The inner pad on drivers side wore out completely the outer pad had same wear as the passenger side.
    I had a hunch.
    I decided to change BOTH Calipers.
    No more drifting to the left, no slight pull when braking.
    YMMV...
    TacoSR523 likes this.
  2. May 28, 2024 at 7:36 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Very good insight there. Yeah, the inconsistent pad wear is a good tell. Glad you figured it out, and also that you shared; it will definitely help someone else out.
  3. May 28, 2024 at 7:50 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I’m guessing it wasn’t the entire caliper, but a piston not retracting well. You can rebuild a caliper as well, or easiest is buying a remanufactured one from Napa and then taking back yours for the core deposit.
  4. May 28, 2024 at 7:55 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Just be careful with rebuilt / remanufactured calipers. A lot depends on the core they start with, the parts they install and the remanufacturing process they use. Some are pretty good. Some are outright junk. I rebuild my own using OEM Toyota parts.
  5. May 28, 2024 at 8:16 AM
    bldegle2
    San Francisco, Ca.
    Spot on. Further examination indicated one end of the pad wore out faster than the other end, definitely a piston hanging causing the weird wear...
