Brake change help
Discussion in 'Wheels & Tires' started by DFPTaco, Oct 19, 2008.
  1. Oct 19, 2008 at 2:38 PM
    DFPTaco
    DFPTaco [OP] It's TACO time!
    Josh
    Woodland Park, CO
    14 DC SB SC TRD SPORT
    Rear diff breather relocate, BLHM, Scanguage II, Toytec Ultimate Lift set at 3" w/AAL, sway bar relocate, front diff drop, WeatherTech mats, TRD cat back exhaust, TRD Supercharger, KMC Enduros, 285/75R16, and full size spare.
    I bought new pads today and I need a little advice swapping them out... I just need to remove the calipers by removing those 2 bolts on the back, then remove old pads, compress calipers, replace pads, and then calipers right? Any tricks to doing the front pads? Any help is appreciated.
  2. Oct 19, 2008 at 2:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Take the cap off the brake fluid resivor before you compress the calipers. Just loosen it enough to let the fluid expand when they are compressed. :)
