Brake check
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfTacoCV, Feb 28, 2024.
  1. Feb 28, 2024 at 7:43 PM
    InfTacoCV
    InfTacoCV [OP] Member
    So I recently replaced my front brakes and pads on my 2016 Taco. I used Raybestos E3 Hybrid pads and Dynamic Friction Rotors. I removed the cap from the Master Cylinder before pushing pistons back. I bled rach side about 12 times when I was done in the off chance I got air in the system. I also replaced the brake fluid with DOT 5.1 while I was bleeding them.
    I bedded the pads best I could over the past few weeks and tested them for anti lock and to make sure truck would stop if I needed hard braking. Everything works as it should. However, the pedal feels softer than before. It was the first time I changed the brakes on this truck OEM pads were down to 2mm.
    Before when I stopped on an incline I would stop and I like the take off assist (manual transmission) and would push down a little harder on the pedal. It would never go to floor. Now under same circumstances if I push pretty hard the pedal will almost go to floor.
    I bled the brakes again today about 8-10 times per side but did not see any obvious indication of air in the system. So I am thinking its one of two things. Either I damaged the master cylinder somehow and it won't build full pressure or the rear drums are out of adjustment. Thoughts?
  2. Feb 29, 2024 at 12:07 PM
    InfTacoCV
    I am thinking master cylinder since it was fine before changing fronts.
  3. Feb 29, 2024 at 12:08 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    What trim level do you have?
    Junkhead and Chew like this.
  4. Feb 29, 2024 at 6:09 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Some might disagree - but it is not wise to push the old brake fluid back into the system. Always crack the bleeder and let it run out as you push the piston in. If the bleeder is frozen - crack the brake line connection to the caliber and point it up. You should not need to bleed the system after that, and if you do - the air is right close to the caliber.
    Junkhead, Big tall dave and willtill like this.
  5. Feb 29, 2024 at 6:20 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Are you sure you put a correct fluid type?
    Looks like Sram bike brake fluid.
    Speaking of bicycles. Why do you need to invent a bicycle?
  6. Feb 29, 2024 at 6:26 PM
    Bishop84
    Bishop84 Well-Known Member
    Always start with a rear adjustment. You bought performance brake parts and you have neglected a very important part of tacoma brake servicing. They need to be adjusted at least every 10,000 miles. Many run the same shoes the entire vehicle life because they dont adjust their shoes.
    When I see caliper push back causing issues there's usually a ABS code triggered, so as long as you dont have a code its likely fine. I'd say adjust shoes, drive for a few days, then rebleed.
    Performance pads can feel weird, even when bedded properly.
    Junkhead, joba27n, RustyGreen and 4 others like this.
  7. Feb 29, 2024 at 7:15 PM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Being an owner of a 3rd gen and having owned a 1st gen tundra both with drum brakes I can definitely second this. Proper adjustment of rear drum brakes is constantly overlooked, and their importance in providing a proper brake pedal height isn't understood very well. I would definitely start there. There's plenty of tutorials on how to do so. Also, anyone correct me if I'm wrong but these, and most drum brakes are self adjusting to the point where the self-adjusting ratchet mechanism will automatically tighten when you hit the brakes real hard (or in reverse?) AS LONG AS your parking brake cable is adjusted properly. I'd start by popping the drums off and adjusting them there first. Then pop the console off and adjust the parking brake cable if it still isn't that tight.
    Hope everything works out for ya!
    Brooks
    willtill likes this.
  8. Feb 29, 2024 at 7:35 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    I've seen Calipers flipped/on the wrong side of the vehicle and it wouldn't allow the brakes to bleed properly.
  9. Feb 29, 2024 at 7:56 PM
    InfTacoCV
    TRD Sport V6
    shakerhood[QUOTED] likes this.
  10. Feb 29, 2024 at 8:00 PM
    InfTacoCV
    Ok I ran out today and backed up a few times and came to to a stop several times to see if the auto adjusters were working and I could definitely feel the pedal becoming firmer. It didn't fix the issue if course but I believe you are correct. I will get them adjusted. Thank you
  11. Mar 1, 2024 at 5:54 AM
    rlevass23
    rlevass23 New Member
    Ron
    2016 Tacoma 3.6l
    Going to add a Pedal Commander and possibly engine coils
  12. Mar 1, 2024 at 6:28 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I believe the self adjustment mechanism on these trucks are actuated by the hand brake, not the reversing method like many domestics
  13. Mar 1, 2024 at 2:45 PM
    InfTacoCV
    Appreciate the thought but 100% sure they are on correctly. Im not sure you could install it backwards or upside down. The brake hose is pretty short and steel the last 6 or 8 inches. You would definitely kink it if you spun the caliper. Im pretty sure its the rear brakes out of adjustment at this point
  14. Mar 1, 2024 at 2:49 PM
    InfTacoCV
    DOT 5 is bike fluid. DOT 5.1 is for pickups. I don't know the difference between it and DOT 4 but I was told by Toyota that 5.1 is compatible. NAPA was out of DOT4 so I went with 5.1. After bleeding I got rid of all old in the front lines.
  15. Mar 3, 2024 at 8:48 PM
    InfTacoCV
    Thanks all for the replies. I decided to try backing up and using e brake to see if it would adjust the rears before hand adjusting. After about 4 good stops the pedal is now much mich better and truck stops better. I thought it was like Ford and Chevy where you back up and use pedal to adjust but I found the procedure through this site with the e brake. Worked like a charm
    joba27n likes this.
  16. Mar 4, 2024 at 7:54 AM
    eurowner
    eurowner Duke Sky
    Scoty
  17. Mar 4, 2024 at 7:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
  18. Mar 4, 2024 at 10:31 AM
    Vlady
    Issy, WA
    I'm skeptical about this method. I've tried with zero changes. Even toyota techs did not believe in it
    https://www.tacomaworld.com/threads/rear-drum-brakes-auto-adjust.813516/
  19. Mar 4, 2024 at 12:54 PM
    joba27n
    Nolan
    Alberta
    In my "lived" experience, the self adjustment is better than nothing but not by much. Every tire rotation you could get atleast a click or two out of them. In my opinion if your brakes are out of adjustment you have to actually manually set them up. The self adjustment isn't a miracle cure. It's basically as useful as a pen cap for you pen
  20. Mar 5, 2024 at 9:05 PM
    InfTacoCV
    Well its been almost a week and the pedal is back to about the same feel as pre brake change and truck definitely stops better. It appears to have worked. No pull when I brake and anti locks work. I have a service due in about 900 miles and will definitely have them checked but they appear to be back to normal
