Brake "click" feel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gardenburgers, Jun 16, 2019.
  1. Jun 16, 2019 at 4:52 PM
    gardenburgers
    gardenburgers [OP] Member
    2019 Tacoma OR DCSB
    Hi all,
    I have a new 2019 TRDOR and I noticed that when I start to depress the brake pedal, there is a "click" feeling before it actually starts to brake. It does NOT make a clicking SOUND, which I read about on the forum is a common issue on previous models, but it's kind of annoying that every time I brake it feels like there's some "give" or "looseness". This is especially bad in stop-and-go traffic, since I'm braking so often. Had taken it into the dealership but they said everything looks fine.
    Is this normal? Unfortunately it's hard to describe as its not something that can be captured on video. Thanks all!
    a400ryan and graullerson like this.
  2. Jun 16, 2019 at 5:21 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    I haven’t experienced this in either of my 3rd gens. Take it to the dealer. If they can feel it they should fix it.
    shakerhood and Boghog1 like this.
  3. Jun 16, 2019 at 5:37 PM
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    KCMO
    98 T100
    I have it on my 19 DCOR, annoying as heck and yes starts to feel loose in stop n go
  4. Jun 16, 2019 at 5:39 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    The “click” is your brake light actuator. It will fade away as you use the brake pedal more
    Bluebros, 2016Tacoman and tallpilot like this.
  5. Jun 16, 2019 at 5:46 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try reversing and hitting the brakes that may readjust the rear brakes
    a400ryan likes this.
  6. Jun 16, 2019 at 5:53 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Correct. Off-roads have an electric hydraulic power pack for the brakes. They take some getting used to if you are coming from something with a vacuum booster.
    Ease into the pedal enough to make the pump spin up. Then they will feel quite linear.
    camillethetoy and Steves104x4 like this.
  7. Jun 16, 2019 at 6:28 PM
    gitacotrd
    gitacotrd Well-Known Member
    Marc
    Texas
    2018 Cement TRD offroad
    Avid lightbar, Eibach 2in lift, various TRD parts
    Yup both off-road 3rd gens I had do it.
  8. Jun 16, 2019 at 7:04 PM
    gardenburgers
    2019 Tacoma OR DCSB
    I was driving a current-gen F150 and a 2012 Honda Civic previously, and both had much smoother braking than my Taco.
    I have noticed that when I ease into the pedal VERY lightly it sometimes does not occur, but I really have to focus on it and can't do this in the city where everyone is stopping suddenly/being a dick in general. Even when I have plenty of time to brake and try to ease into it I still feel the click/jolt about 50% of the time.
  9. Jun 16, 2019 at 7:06 PM
    Steemax
    Steemax Well-Known Member
    SoCal
    2019 Cement TRD OR 4x4 DCSB
    Yup my 2019 OR does it as well... chalked it up to being normal.
    camillethetoy likes this.
  10. Apr 26, 2021 at 8:15 PM
    Foster4x4
    Foster4x4 Member
    Massachusetts
    21’ DCSB MT, 07' RCLB MT
    Alu-Cab Canopy Camper, OME BP-51s, DD PRO FOGS, 17" rims with 285K02s.
    My 2020 Off Road is doing this as well. I tested it at a dead stop. It clicks every other time it’s depressed. It’s super annoying and the dealer tells me this is normal.
  11. Apr 26, 2021 at 8:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No weird braking abnormalities on my truck.
  12. Apr 26, 2021 at 8:22 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Solved the same way I solved car noise for decades...more volume Scotty.
    Junkhead likes this.
  13. Apr 28, 2021 at 8:42 AM
    KazmanN
    KazmanN Member
    Utah
    2018 Tacoma SR5 4x4
    Its the characteristic of our trucks. I have a click as well, but it only happens once forward or in reverse. Its the caliper/pad design from what I was told. There is some play in the brake pad (by design), and what you are hearing is the pad shifting forward or back depending on the direction you're driving. I had a private owned shop and the dealership look at it when I thought it was an issue and they both told me the same thing. The noise is annoying, but I notice zero difference in braking performance.
    cbouch001 likes this.
  14. Apr 28, 2021 at 2:46 PM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    My wife’s 2016 Corolla does the exact same thing, she says she doesn’t notice it, it however makes me nuts when I have to drive it anywhere. My truck on the other hand does not have the *click* so while it’s obviously not dangerous, it isn’t normal by any means IMO.
    If you are referring to what I am, I completely understand. It feels almost like it’s cable operated and is seized, and then suddenly releases for about 1/16-1/8” and then again is firm. I know it obviously isn’t cable operated but that’s the best analogy I can think of off hand.
    Our trucks do also making a “click” or “clunk” as the pads move around and contact the caliper, but again I don’t believe you are referring to that.
  15. Apr 28, 2021 at 6:57 PM
    Foster4x4
    Foster4x4 Member
    Massachusetts
    For me there’s no sound associated with this. It’s just a feeling in the pedal.
    graullerson likes this.
  16. May 14, 2021 at 1:13 PM
    graullerson
    graullerson Member
    WA
    2021 LR Taco-Pro
    Yes my 2021 Pro does this same thing. I think it feels like a quick pulse and release, somewhat like an abs system feels when engaged. I wouldn't say it is normal, just something that owners deal with.
  17. May 14, 2021 at 4:33 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Normal for Toyota .... the brakes are pretty dated . Toyota needs to get with the program hopefully 4th gen will finally address the brakes .
  18. May 15, 2021 at 7:03 PM
    BOSS-DS2
    Sam
    Texas
    I still don’t think he is referring to the normal pad movement that the majority of commenters are.
  19. May 3, 2022 at 7:23 AM
    Troutmaster
    Troutmaster Member
    2015 Tacoma
    Iebach shocks
    I have the same issue you speak of with my 2020 off road. I feel it in the gas pedal also. I haven’t brought it to the dealership yet. Seemed to be doing it from day one.
  20. May 3, 2022 at 9:04 AM
    azpatnca
    azpatnca Active Member
    Patrick
    2018 SR5 4x4 Superwhite
    Sounds like there are two things going on.
    1. On ORs, there is a different mechanical approach to power braking, and it feels different than the other 99% of cars made since 1960nor whenever power brakes became a thing.
    2. On all Tacoma's there is a once-a-day slip that happens the first time you brake, usually in reverse and maybe once again the first time you brake going forward. It's annoying and everyone says it's normal. No one has died from it and there haven't been any recalls. It's just annoying and concerning every day, once a day,not think your shiny new truck isn't working right.
    My SR5 definitely has (2), that one time clunk. I thought it was the AT, but maybe that's a different clunk. I imagine OR drivers will get used to their braking system and then be upset if it ever changes to something different.
    I tell you, the RAV4 steering is electric, not pneumatic, and it drives me crazy. But I guess no PS fluid changes are a nice benefit. So I'm sure there's some benefits to the OR braking approach.
