Brake click fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 18, 2011.
  1. May 18, 2011 at 12:51 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    So after a quick search on TW I found that the front brake click I was hearing the first time a depressed the brakes was the pads shifting in the calipers...after reading a bunch of threads it appears this is NORMAL. my question is, is there any fix besides buying fresh pads?
  2. May 18, 2011 at 12:55 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    I dont think fresh pads will fix it either. My 2011 does it as well. It doesnt bother me but it is kind of embarrasing at like a gas station or something where people can hear, because it can be loud sometimes.
  3. May 18, 2011 at 1:01 PM
    TOYOTA 09
    Maine
    Agreed^ that's why I'm looking for a fix... I thought I read somewhere about a tab fix with grease?
  4. Oct 8, 2011 at 3:12 PM
    TOYOTA 09
    Maine
    ANYONE?
  5. Oct 8, 2011 at 5:19 PM
    Tacoma Mike
    Southern Maine
    I usually use the rear brake tsb grease for the camry.
    Works pretty good. Use it on the pins, pad backs and edges.
    Very thick. not perfect but it helps quite a bit.
  6. Oct 8, 2011 at 5:44 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  7. Oct 8, 2011 at 5:51 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I has it too. Annoying.
  8. Oct 17, 2011 at 7:36 AM
    sdupp
    sdupp SC Member
    SC
    White 07 PreRunner Double Cab SR5
    The problem started for me around 55k and @ 60k I took it to my mechanic for its first brake job. He showed me where the pads are hitting inside the calipers. He installed a new set of OEM brake pads and the problem is still there. He took them back off and tried without the shims and lots of brake grease. Still make same noise. I wish someone could come up with a solution for this issue. Its firkin annoying & just another quality defect this Tacoma has. If that Honda Ridgeline wasn’t so ugly I would trade this Tacoma in for one tomorrow.
  9. Oct 17, 2011 at 7:38 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Mine does not have this issue...weird.
    Fink
  10. Oct 17, 2011 at 7:42 AM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    im due for brakes, so when i change mine i will investigate.....
  11. Oct 17, 2011 at 10:04 AM
    steelerfan7p
    steelerfan7p My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    Guy at the dealership told me to replace the pins. He said they corrode and end up just a little smaller than the holes which causes the calipers to shift. I haven't tried replacing mine yet so i dont know if this works.
  12. Oct 17, 2011 at 10:14 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I had this issue the first couple years but since then it's gone away (truck now has 17,800 miles.)
  13. Oct 17, 2011 at 10:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I didn't until this past year, right around when I crossed 50k miles. I just live with it... it seems worse in the morning when I first start driving.
  14. Oct 17, 2011 at 10:37 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    My truck has had the clicking noise since it was new; she now has 42,xxx.
    I've pulled up next to people in traffic and they tried to tell me my wheel bearings were shot....haha
  15. Oct 17, 2011 at 10:39 AM
    Fink
    Orlando, FL
    Hmm...I'll have to listen for this. My 2007 never had it, that I can remember, but I sold it when it had 47k on it.
    Great...another thing to obsess about. :p
    Fink
  16. Oct 17, 2011 at 7:02 PM
    TOYOTA 09
    Maine
    Mine started doing this at about 20-25k
  17. Oct 17, 2011 at 7:13 PM
    mhuff29
    mhuff29 TÅpƐwo®m
    Arvada, CO
    05 Tacoma Double Cab SR5
    Air Filter (K&N) Wheels & Tires
    Mine has been doing it since 30000 miles I now have 58K. Took it to the dealership but of course it didn't make the sound for them...
  18. Oct 18, 2011 at 5:39 AM
    TOYOTA 09
    Maine
    lets pool our brain power together and come up with a fix for this.....it makes my truck sound like it's falling apart
  19. Oct 18, 2011 at 5:48 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Did you not see my post?
    I got that info by PMing the OP in that thread.
  20. Oct 20, 2011 at 3:42 PM
    sdupp
    sdupp SC Member
    SC
    I have read your post. Did applying gel grease solve your problem permanently? Because I did install new pads and applied lots of brake grease to the back of the pads. IT DID NOT fix the problem.:confused:
