Brake click fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 18, 2011.
  1. Oct 4, 2014 at 10:50 PM
    #41
    LadTacoma
    LadTacoma Well-Known Member
    Ray
    NJ
    Prime Mover
    Yep mine does it every time I reverse. started at around 30K miles. It's loud and annoying. Thanks for all the tips. I will let y'all know what I break after I try to fix it. :)
  2. Oct 8, 2014 at 11:47 AM
    #42
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
  3. Nov 12, 2014 at 10:53 AM
    #43
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    Just ordered the extra springs...
  4. Nov 12, 2014 at 11:45 AM
    #44
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    I added the extra spring and it helped some. But with a firm 3" lift and running extra PSI in the tires it still clacks on bumps and when braking after reversing direction. So I just turn up the music! :rockband:
  5. Nov 18, 2014 at 8:12 PM
    #45
    TOYOTA 09
    Maine
    Mine never make noise on bumps...just when applying the brakes
  6. Nov 24, 2014 at 9:13 AM
    #46
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Mine does it after reversing or vice-versa the first time the brakes are applied . Pretty damned loud , too .
    Guess I'll try the spring , probably have a pair from the Cruiser as their all about the same size/shape .
    Sarge
  7. Nov 24, 2014 at 9:20 AM
    #47
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Hey gang,
    I might need to start a new thread for this but will these springs help my issue I'm having with my passenger side clicking as I go down the road? My ticking/clicking issue started after I did my front brakes (rotors and pads).
    As soon as I apply the brakes whether it be hard or just barely touch the peddle the ticking goes away. As soon as I release the brakes it comes back immediately only on the passenger side. To me it seems the pad is tapping the rotor as it spins? Driving me nuts.
  8. Nov 25, 2014 at 2:41 PM
    #48
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Just installed the 2nd set of springs and I still have the "click".
  9. Nov 25, 2014 at 4:33 PM
    #49
    TOYOTA 09
    Maine
    WTF? Others said this fixed the click...God dam mother &$!?%#
  10. Nov 25, 2014 at 6:13 PM
    #50
    Sig45
    Mark
    Maine
    First words out of my mouth too!
  11. Jan 3, 2015 at 8:49 PM
    #51
    bigcrab
    bigcrab Well-Known Member
    2014 DCSB 4x4 TRD OR
    installed 2nd set of springs today, so far i feel like the constant click at low speed is gone, still makes a noise when i apply the brake.
    also i noticed one of the factory springs was not assembled correctly on the passenger side ( sounded like that's where the noise was coming from to me) truck has 13 k on it so no brake jobs ever
    look in the lower left :
    corrected :
  12. Feb 10, 2015 at 9:45 AM
    #52
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I did my front brakes this weekend right past 50k on the OEM pads.
    1. Replaced with Akebono ACT976 Pads
    2. Had both rotors re-surfaced
    3. Replaced ALL the hardware (Caliper Pins, Anti-Rattle Clips, Cotter pins)
    4. Added (1) addtl. "Anti-Rattle" clip (spring) to the top of each caliper
    5. Greased everything (pads, shims, caliper pins)
    My low-speed brake click is GONE!!! :D
    My brakes are completely silent now, and more even/responsive with the pressure. No more squishy/spongey brakes, and no more pulsing from the rotors. They feel great, better than when I first bought the truck!
    Complete front-end brake job for under $70?! Hell Yeah!!! :headbang:
    Mush Mouse likes this.
  13. Aug 3, 2015 at 11:23 AM
    #53
    scotty2tymes
    scotty2tymes Member
    scott
    Pittsburgh,PA
    2015 silver sky dclb
  14. Aug 3, 2015 at 11:29 AM
    #54
    scotty2tymes
    scotty2tymes Member
    scott
    Pittsburgh,PA
    Following
  15. Aug 3, 2015 at 11:49 AM
    #55
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    correct me if im wrong cus i just developed a louder metalic click / bang. But it only seems to do it after i have driven the truck parked, let it cool, back out and go over a speed bump. I wonder if adding this clip would fix my issue.
  16. Aug 3, 2015 at 11:50 AM
    #56
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Try it, it worked for my brake click. I had the same symptoms as you described.
    $5 and 10 minutes later you will have your answer :)
  17. Aug 3, 2015 at 11:58 AM
    #57
    Large
    Large Red
    I was thinking this was my click / tap when I apply brakes at low speed as well. Turns out the alignment tech didn't torque my LCA cam bolts properly after an alignment and one was hand tight. Torqued to 100 ft lbs (155 ft lbs for 2wd) and it went away. I also installed these anyway just in case and the noise hasn't come back. That was 6 months ago or so.
  18. Aug 4, 2015 at 7:31 AM
    #58
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    Installed new brakes on my truck, originals had 93k on them. Added the second spring and brake quiet spray and no issues yet. My brakes knocked quite a bit before.
  19. Sep 18, 2015 at 7:41 AM
    #59
    MonTaco
    MonTaco Beard Enthusiast
    SLC
    13 DBL Cab LB TRD Sport
    Mine is making the same noise and it's driving me crazy! I ordered some new clips. They'll be here in a couple days and I'm hoping it'll solve the issue. If not I guess I'm only out $5. :fingerscrossed:
  20. Oct 6, 2016 at 4:56 PM
    #60
    slicked1
    slicked1 Old dog w/ Toy
    Kansas City
    2013 Taco TRD
    quick mods so far
    Yes, it was the brakes on my 2013. So for any of you looking for the fix, here is what I did. I replaced all 4 pins, replaced the two old springs and added two new springs on the top pads (total $20 from Toyota) . I also cleaned the squeal plates and removed any corrosion on the plates from the brake pistons using a razor blade. The pads still had 75% of the lining left....no need to change them.
    No more brake click.
    bski22 and WebberLander like this.
