Brake clicking
Discussion in '1st Gen. Tacomas (1995-2004)' started by evanspen06, Feb 26, 2024.
  1. Feb 26, 2024 at 8:43 PM
    evanspen06
    evanspen06 [OP] Well-Known Member
    Anyone know why there’s a clicking noise when I brake. It’s o. The front brake.
    wilcam47 likes this.
  2. Feb 26, 2024 at 10:00 PM
    02hilux
    Planet: EARTH
    ABS pump?
  3. Feb 26, 2024 at 10:03 PM
    evanspen06
    I don’t think I have abs but will check tomorrow.
  4. Feb 26, 2024 at 10:04 PM
    02hilux
    Planet: EARTH
    If you don't have abs, you'll need to explain more in detail on the clicking noise.
    Might be brake booster
  5. Feb 26, 2024 at 10:04 PM
    evanspen06
    It’s more down toward the actual caliper. The caliper bolts aren’t loss. Would something like the pads be loose or something like that.
  6. Feb 26, 2024 at 10:05 PM
    evanspen06
    It’s wasn’t clicking a week or two ago unless I was braking hard but this week it’s is clicking pretty much every time I brake.
  7. Feb 26, 2024 at 10:05 PM
    02hilux
    Planet: EARTH
    Will need more info on your truck. 4x4/prerunner 6 lug or 5 lug?
  8. Feb 26, 2024 at 10:06 PM
    evanspen06
    6 lug 4x4 2001 locking diff
  9. Feb 26, 2024 at 10:06 PM
    02hilux
    Planet: EARTH
    You sure the rotor is not getting hit by the low indicator on the pads?
  10. Feb 26, 2024 at 10:07 PM
    evanspen06
    I just did the pads a few months ago
  11. Feb 26, 2024 at 10:08 PM
    02hilux
    Planet: EARTH
    Then I would take the wheel back off and inspect. Could be anything at this point. Old warp rotor with new pads? Is the pad lube properly? Shim? Etc
    Andy01DblCabTacoma likes this.
  12. Feb 26, 2024 at 10:10 PM
    evanspen06
    Ok will do. Thanks
  13. Mar 1, 2024 at 10:31 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Sounds like the problem I had after I replaced the pads several years ago. I had a metallic "clacking" noise when I tapped the brake pedal while the truck was rolling backwards. Both wheels made the noise. Tapping the backing plate kinda duplicated the noise. Drove me crazy.
    Then about a year ago I replaced the pads again, and the noise went away. I used Toyota OEM pads for the first replacement, and then Advic pads (from Advance Auto, part number N10101456304 ADVPS534 ). Other than that, I reused all parts.
  14. Mar 1, 2024 at 10:48 AM
    evanspen06
