Brake clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justinike89, Oct 2, 2012.
  1. Oct 2, 2012 at 8:31 PM
    Justinike89
    Justinike89 [OP] New Member
    06 trd off road
    Hey everyone I have just recently gotten an 06 tacoma trd off road. I have a really weird sound coming from my front end when I'm going under 30 mph that clicks when I press on the brake pedal. At first I thought it could be the transmission just dropping into first (I had a couple of Fords that did that) but I realized it happens when I press the brake pedal. I have not had time to take a look just yet, but I will look soon. If anyone has any ideas please let me know.
    Thank you.
  2. Oct 2, 2012 at 9:25 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    its the brake pads. for the most part normal. I've seen alot of tacos do it... depending on your mileage, they could be getting low, but mine always do it when I change directions and the first time I step on the brake going in that direction.
  3. Oct 18, 2012 at 2:44 PM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    I get that, too, but I thought it was coming from the rear. It happens the first time I press my brakes while backing up.
  4. Oct 18, 2012 at 2:46 PM
    RoninTaco
    RoninTaco Well-Known Member
    Scott
    Kansas City
    09 Off-Road Super White
    x2
  5. Oct 18, 2012 at 2:50 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    It's normal, mine do it when I back out of my driveway.
  6. Dec 27, 2012 at 9:00 PM
    RichieW13
    RichieW13 Well-Known Member
    Richie
    Thousand Oaks, CA
    2008 PreRunner Sport
    This is so crazy. I HATE listening to that clunk. For the first time in my life I spent a lot of money to buy a vehicle, and was hoping I wouldn't have to deal with bad noises and broken crap. So far the Tacoma is not holding up its end on that.
    How is clunking brakes just expected to be "normal"? Why can every other vehicle sold avoid this problem?
    Has anybody figured out a fix for this?
  7. Dec 27, 2012 at 10:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get new pads......
    I had the clunk for a good couple years....(or more, can't remember). It would happen mostly when changing direction the first time and applying the brakes.
    This past summer, I had my rotors turned and changed the pads...greased pins, new anti-squeel material .... and the clunk is completely gone.
    Perhaps this is something that occurs when the pads are getting worn. Mine had about 3/16" of pad left @ 52,000 Miles. I installed OEM brake pads.
  8. Mar 26, 2013 at 9:58 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    Sacramento
    2008 TRD Off-Road
    Whatever I buy when I'm drunk
    I pulled mine off to see what the clunk was, seems to be the rotor.
    If you look at the rotor and the holes for the lugs, there's a bit of space. When changing directions, or applying brakes under 30mph the rotor is stopped, but the hub/lugs keep rotating until they knock the other side of lug holes.
  9. Mar 26, 2013 at 10:56 AM
    Janster
    Jandy
    Lancaster, PA
    Got any picts? Having a hard time thinking of what you're referring to.
    If you're saying, the rotor is slipping between the hub & lug nuts in the holes - then you don't have the wheels torqued tight enough (and not even close). I believe the factory torque spec is 85ft lbs. I use 100ft lbs.
    The lug nuts are what hold the rotor & wheel tightly to the hub. If there's any slop or play ..it's not tight enough. Unless you're referring to something else.
  10. Mar 26, 2013 at 11:05 AM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    When I ordered new pads and rotors and installed them, I heard a bad clunking noise. It ended up being the rotors. The lug holes were 1 mm larger than the rotors I replaced. I returned those and got a new set and the holes were the same size are the originals I replaced. The Noise went away. I torqued the wheels to spec with both sets of rotors.
    You can see the extra space with this picture.
  11. Mar 26, 2013 at 11:10 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5
    2007: Avid sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, blisten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scanguage, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload
    Glad to know this is somewhat normal. I've been trying to locate this clunk for the longest time. I used to think it was my lift, but then I realized it was when I used the brake, usually after just having backed up/starting in motion/having the wheels turned, etc.
  12. Mar 26, 2013 at 11:11 AM
    Janster
    Jandy
    Lancaster, PA
    Improper parts certainly won't help. !!
  13. Mar 26, 2013 at 11:11 AM
    RichieW13
    Richie
    Thousand Oaks, CA
    If it's the rotor holes like in that picture, would it be possible to make some kind of sleeves to put over the lugs to stop the "clunk"? Or is that just too high stress of an area for something to stay in there?
    I bought my Tacoma from a dealership with about 20,000 miles on it. I would assume that the stock rotors are still on there. Could the stock rotors have the wrong size holes?
  14. Mar 26, 2013 at 11:15 AM
    Janster
    Jandy
    Lancaster, PA
    Get the right fitting parts.
    Putting sleeves in is like a band-aid.
    How many miles on the truck? What do the rotors/pads look like?
    I had a clunk - factory rotors and pads with 55k miles on them. I was due for a brake change (only 3/16th material left. I changed my pads and had the rotors turned and no more clunk.
  15. Mar 26, 2013 at 11:18 AM
    JTacoma
    Washington
    What was odd is that the part numbers of the new set were the same as the ones with the wrong sized holes. The first set must have been packaged incorrectly from the factory.
  16. Mar 26, 2013 at 11:24 AM
    RichieW13
    Richie
    Thousand Oaks, CA
    I'm at 58,000. How would turning the rotors solve the problem of loose lug holes?
  17. Mar 26, 2013 at 11:59 AM
    bucksnort06
    bucksnort06 Well-Known Member
    pete
    cape cod
    09 TRD
    4 leaf TSB, 5100's all four, eibach 1.6" coils, ARE cx cap, yakima racks, weathertech floor mats/rain guard/hood guard.
    I had a horrible clunk like you describe.. Just replaced pads and rotors last weekend and the clunk is gone..
  18. Mar 26, 2013 at 6:20 PM
    Janster
    Jandy
    Lancaster, PA
    I never said it would.....
    The person who mentioned the large lug holes -appears to be uncertain if that's the case. Highly doubtful that stock rotors from the factory would be improperly sized.
    Hence - I mentioned that I had a similar clunk as my brakes got older. I changed my pads and had my rotors turned and the clunk went away. I always have my rotors turned when I change pads.
  19. Mar 26, 2013 at 7:13 PM
    RichieW13
    Richie
    Thousand Oaks, CA
    Oops. I guess I read too much into your post following the other posts, and inferred that you were also saying the lug holes were too large.
  20. Mar 26, 2013 at 9:37 PM
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    The noises is cause by the brake pads due to the play that they have on the slide pins and in the caliper. The pads need to be lubed on each end and the noise will go away.
