Brake Controller and 7 Pin Installation on 2017 Tacoma Questions
Discussion in 'Towing' started by justinh384, Oct 24, 2021.
  1. Oct 24, 2021 at 10:18 AM
    justinh384
    justinh384 [OP] Active Member
    Justin
    Wrightsville, GA
    2017 White Toyota Tacoma SR
    I am trying to install both a 7 pin connector and a trailer brake controller on my 2017 Tacoma. I already have 4 pin wiring in place. It is my understanding that since my truck is not prewired I’ll need to hard wire the brake controller and run the wires myself. My only question is which wire should I tap into for the stop light switch. I found a connector behind the brake pedal with 4 wires.
  2. Jan 3, 2022 at 10:31 AM
    Aleeoop70
    Aleeoop70 New Member
    Alec
    2017 White 4X4 SR5 auto 6'bed, access cab
    285 70 R17 tires, black step rails
    Your post was in October so this may no longer be relevant for you. Do you still need this information? I'm going to do the same installation you are doing soon and I believe I have figured out a process that will work, correctly identifying the wire without damage while standing on my head under the steering wheel.
