Brake controller for pop up camper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gfunk123, Jul 17, 2018.
  1. Jul 17, 2018 at 6:13 PM
    Gfunk123
    Gfunk123 [OP] Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Any advice on brand or places to purchase a brake controller would be great.
  2. Jul 17, 2018 at 6:21 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Etrailer.com had good prices and selection when I was looking.
  3. Jul 17, 2018 at 6:38 PM
    NGeorgiaTacoma
    NGeorgiaTacoma Well-Known Member
    NE Georgia
    2014 Full Access Cab 4-cyl
    Popup campers typically don't weigh enough to require electric brakes. Typically only trailers somewhere around 2000# or more need electric brakes. If electric brakes came on the trailer, and you'd like to have them operable to be safe, then a simple and inexpensive time-based controller will work fine. From there, the heavier the trailer gets, then the more complex (and expensive) the controller gets. For example a heavy 4500# trailer might require a high-end inertia-based controller.
    Time-based controllers use a simple timing circuit to apply the brakes. Those can be mounted in any position, and can even be loose on the console becasue position is not important. Inertia-based controllers have very sensitive sensors that measure the deceleration during braking and apply the trailer brakes in accordance with the rapidity of the stop. Those type controllers need to be hard mounted, typically on the kick panel under the dash. Both types typically have manual overrides to use in case of emergency, so both need to be near the driver.
    Curt has lots of documents on this and you can see all 5 of their controllers.... https://www.curtmfg.com/application-guides
    Pick out your controller, then go to Amazon. You'll find the controller you need at half of list price. Don't forget, you'll also need the correct controller harness to make the connection to your truck.
    A visit to the Towing forum on this web site will answer most questions. https://www.tacomaworld.com/forums/towing.34/
  4. Jul 18, 2018 at 6:25 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've got one of the Tekonsha Prodigy units in my truck. I can't recall the exact model off the top of my head and I'm too lazy to walk outside and look but I've had it for a couple of years now. This is the current version: https://www.etrailer.com/Brake-Controller/Tekonsha/90195.html I got mine from a local trailer place and installed it myself in a couple of minutes. One of the features that I like is that it can be mounted at an angle under the dash (still needs to be in line with direction of travel) and that it's easily removable since I've only needed it a couple of times.
    If your truck came with the towing package it should have the connector behind the left kick panel, it just required the proper harness to connect the controller and two screw holes to mount the bracket.
    SamuelJ likes this.
  5. Jul 18, 2018 at 7:49 AM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    I did not even permantly mount mine. I just put it in the pocket above the gas peddle. It can then be removed and put in the center console when not needed.
    Sharpish likes this.
  6. Jul 18, 2018 at 7:55 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    that could be problematic if someone banged the controller or it slid around the sensors might register the truck as braking when it's not or braking harder than it really is. Might make for some exciting trailer braking.
  7. Jul 18, 2018 at 3:04 PM
    Gfunk123
    '13 limited taco
    I just picked up a primus iq w the toyota wiring harness for $45 on Craigslist. There is one extra white wire that comes out of the harness. Is that not needed if I have the factory towing package?
  8. Jul 18, 2018 at 3:21 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  9. Jul 18, 2018 at 3:25 PM
    RicanTacoma
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Still works Click on the
    Watch this video on YouTube link.
    Gfunk123[OP] likes this.
  10. Jul 18, 2018 at 7:39 PM
    Gfunk123
    '13 limited taco
    Thanks!!!
  11. Jul 20, 2018 at 7:41 AM
    potstech
    Midlothian, Va
    2013 DCLB
    It has been there for over 4 years without a single problem. It is recessed enough that it would be very difficult to bang it and there is minimul sliding around.
  12. Jul 20, 2018 at 8:40 AM
    41magmag41
    41magmag41 Well-Known Member
    jim
    New Hamshiire
    tacoma double cab TRD 4 x 4
    I think you'll find that most states require brakes on any trailer over 1500 lbs gross vehicle weight. Tenosha is an excellent brand of brake controller.
  13. Jul 23, 2018 at 10:03 AM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Second the tekonsha prodigy. Ive run mine for several years to control braking on my 81 jayco pop up. Works great.
  14. Jul 23, 2018 at 2:27 PM
    John Mc
    John Mc Well-Known Member
    Vermont
    2009 Tacoma SR5 4x4 Access Cab
    Added trans & engine oil coolers. (No factory tow pkg)
    I used a Tekonsha Prodigy P3 with the pop-up camper behind my minivan years ago. It worked out well enough that I'm having one installed in my Tacoma now. One of the things I like about it is the ability to store several different trailer profiles and call them up with a couple touches of a button. So when hauling my pop-up (about 2500#) I can have a less aggressive braking profile than when hauling a 5000# load of firewood (and a third profile for when that firewood trailer is empty).
