Brake Controller Harness Location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rrcbob, Apr 19, 2021.
  1. Apr 19, 2021 at 9:27 AM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    Trying to confirm the location of the brake controller connector on a 2021 Tacoma base. The REDARC instructions for their connector TPH-015 says it’s center left (location B) but I think I’ve seen actual experience on this site that it’s C, A, or H.
    Anyone have actual experience on a 2021?
    REDARC_Ryan and slidemx5 like this.
  2. Apr 19, 2021 at 10:59 AM
    slidemx5
    slidemx5 Well-Known Member
    Rob
    21 DCSB OR Manual!
    On my 2021 TRD Off Road, the harness was behind the driver side kick panel. Roughly where 'A' in your diagram shows. It is to the left and 'above' the dead pedal rest area.
    I installed my Redarc and it was right there. I pulled the drivers door sill panel, then the kick panel (don't forget there is a thumb screw, i broke the screw...woops!) then it should be there. My connector was white.
    let me know if you need a pic
  3. Apr 19, 2021 at 10:59 AM
    caribe makaira
    Caribbean, Puerto Rico
    Remove the driver's kick panel, you'll have to fish for it behind the connectors junction block.
  4. Apr 19, 2021 at 12:37 PM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Just installed mine a few weeks ago and it was like the photo above. Could not see it but felt around behind that wire harness and there it was
    REDARC_Ryan and rrcbob[OP] like this.
  5. Apr 19, 2021 at 1:11 PM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    Same here. I was looking higher up thinking to myself.. WTF... watched a video to see the location and it was stuffed behind another harness with little slack on it. Had to connect it blindly.
  6. Apr 19, 2021 at 3:24 PM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    Thanks, this is helpful. Where did you attach the box and ground?
  7. Apr 19, 2021 at 4:04 PM
    Chaosh1
    2021 Tacoma TRD Pro
    Ground wire is attached to that bolt to the right of the connectors.. White wire
    REDARC_Ryan likes this.
  8. Apr 19, 2021 at 5:51 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    This. ^ it's hidden as hell
  9. Apr 19, 2021 at 7:35 PM
    s4nsc
    s4nsc The chicken stays…
    St. Augustine, FL
    2024 GMC Sierra AT4X
    That’s putting it mildly. I couldn’t find mine and only kept looking because I had seen a thread on here about it. Finally felt it and pulled it out to confirm that was is.
    I mounted the controller with some of the 3M double sided tape to the side of one of the other boxes in that same area. It is also wedged into place so I’m not too worried about it coming loose.
    stealthmode[QUOTED] likes this.
  10. Apr 26, 2021 at 10:20 AM
    k14553n
    k14553n New Member
    2021 Tacoma TRD Off-Road
    The harness and ground were same as above on our 2021. Just thought I'd share a good spot to mount the controller. Super stable, and nowhere near the knee airbag.PXL_20210426_170930820.jpg
    VirusCage and stealthmode like this.
