Brake controller install location in 2013 PreRunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spindifferent, Mar 22, 2013.
  1. Mar 22, 2013 at 12:28 PM
    Spindifferent
    Spindifferent [OP] Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    Thought I'd pass along where I ended up installing a brake controller in my 2013. I won't need to do much towing - probably only a couple times a year, so I wanted to install the brake controller in a way that was least visible when not in use.
    Basically, I installed the controller in the driver side left-hand coin tray that is also the removable fuse box access panel.
    Only real work needed is to cut an opening in the bottom of the removable coin tray in which the controller cable will pass through.
    Velcro tape was placed on the top/bottom of the inside of the coin tray and on the top/bottom of the controller.
    Here are the photos. Feel free to ask any questions.
    - Spindifferent
  2. Aug 28, 2013 at 4:09 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    The P3 would not work the way you fitted yours.
    I just don't have the heart to mutilate my Taco....yet....
  3. Aug 28, 2013 at 5:21 PM
    romafern
    Rob
    80918 Let's meet!
    go for it, but I can't mutilate my taco.... not yet...
  4. Aug 28, 2013 at 5:57 PM
    tdunc
    tdunc Well-Known Member
    Houston, TX
    2013 DCSB TRD OR
  5. Aug 28, 2013 at 6:25 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    my p3 is in the glove box attached with Velcro. works great. its out of the way and easy access if I need to make adjustments
  6. Aug 28, 2013 at 6:37 PM
    Elmosaurus
    Elmosaurus Well-Known Member
    NorthEast PA
    2016 Tundra Blazing Blue SR5 TRD Crewmax 4x4
    ...and, not really accessible to the driver if the manual brake lever is needed in an emergency?? :p
    j/k, but not really.
    :eek:
  7. Aug 28, 2013 at 9:42 PM
    romafern
    Rob
    80918 Let's meet!
    ^^^^^^^^ postings #8 and #9 x 6.67 trillion!!!!!!
    You better hope you never have to reach for it
  8. Aug 28, 2013 at 10:23 PM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Nice clean install OP
  9. Aug 29, 2013 at 3:37 AM
    fyremanpat
    Pat
    757
    considering the pretty low tow capacity of our trucks Im pretty sure that wont be a problem...
  10. Aug 29, 2013 at 5:00 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I need to leave that tray available for gum.
  11. Aug 29, 2013 at 5:31 AM
    Spindifferent
    Central Texas
    Thanks, all.
    I do sometimes lightly bump the controller when I'm getting out of the truck. I have long legs, so I have to remember that the controller is there when I get out.
    The other issue is that the velcro works really well, so it can be some effort to get the controller out of the tray. One option would be to only put the velcro on one side of the inside of the tray instead of top and bottom like I did.
  12. May 25, 2019 at 7:38 PM
    david90291
    david90291 Active Member
    Oregon
    Old post, but happy to find it. This install worked with the same controller on my 2009 Tacoma. Very happy to find this. I don't have any velcro, but it seems like it might be good without it. I may still add it but the controller stays in the coin cup by gravity and the cable holding it in. Perhaps it should be more secure in case I need to brake. My jig saw did not make nice clean lines like the OP, but it works nonetheless and is virtually invisible.
  13. May 27, 2019 at 5:52 AM
    Spindifferent
    Central Texas
    :thumbsup:
