Brake Controller wiring question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slick-Willie, Sep 10, 2015.
  1. Sep 10, 2015 at 8:31 PM
    Slick-Willie
    Slick-Willie [OP] Active Member
    Bill
    AZ
    05 Tacoma
    none
    05 DCSB with factory tow package, installing a Prodigy P2
    the P2 has 4 wires Red-White-Blue-Black
    White is ground
    Blue is brake output to the trailer connector
    Black is 12 volt power to the brake controller
    Red is for the stop light switch
    the factory pigtail Wire, Cowl, No.2 82132-0C010 has 5 wires < everything i have read says this is the correct one for the 05 tacoma, they don't make a plug and play harness for 05 but they offer one for 07 and up. OF COURSE my truck should have had this wire, cowl, no.2 but didn't, SO! i bought one.
    wires are as follows, Black W/red tracer, Solid red, Brown, Green W/white tracer and Solid green.
    The GREEN W/ WHITE TRACER is the stoplight switch.
    The BLACK W/ RED TRACER is the (+) power to the controller.
    The SOLID RED is the output from the brake controller to the trailer itself
    The SOLID BROWN is the ground (-)
    The SOLID GREEN ??
    Please correct me if i'm wrong, it should hook up large black w/red tracer to black
    large Red to Blue, Brown to White< both grounds, and Red to Green w/white tracer.? correct?
    What about the Solid Green? where does it hook to?
    now, if i can only find where it plugs in at! getting in there to look is not easy for a big guy! lol
  2. Sep 10, 2015 at 8:37 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    5 Wires... A black/red, green, red, brown, and green/white.
    BLACK W/ RED (+) power to the controller
    GREEN W/ WHITE trailer brakes
    RED brake controller output
    BROWN ground (-)
    GREEN illumination circuit. If no illuminated controller just tape this out of the way.
    Hope this helps.
  3. Sep 11, 2015 at 7:02 PM
    Slick-Willie
    Bill
    AZ
    05 Tacoma
    none
    still don't know if i need the solid green wire with the prodigy P2. anyone know for sure?
  4. Sep 11, 2015 at 8:43 PM
    mountainwolfpup
    Vancouver, WA
    Sorry. I assumed my response was clear.
    You do not need the green wire, it has no functional purpose beyong illuminating (lighting up) the display and/or indicator lights. Many controllers don't even have an illumination capability.
    You can safely leave the green color wore unconnected.
  5. Sep 12, 2015 at 8:24 AM
    Slick-Willie
    Bill
    AZ
    05 Tacoma
    none
    Thank You!
