Brake drum balance weight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Billyboy, Aug 26, 2017.
  1. Aug 26, 2017 at 10:52 AM
    Billyboy
    Billyboy [OP] New Member
    2008 tacoma access cab 2WD
    None
    while removing rear brake drum on 2008 Tacoma the spot welded weight fell off the drum. Hate to buy a new drum as it is in good shape. Do I need to have that welded back on ( which would probably cost almost as much as new drum) or just let it go? How critical is it?
  2. Aug 26, 2017 at 10:56 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    reassemble and see if you can tell a difference. don't know that i've ever seen one on an aftermarket drum, but its been years since I've installed one.
    odds are the only reason you know is gone is you knocked it off, if it had fallen off prior you likely would never have noticed or known
  3. Aug 26, 2017 at 11:01 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Exactly that.
    Knocked off one of mine of last year.
    Can't tell any diff.
  4. Aug 26, 2017 at 12:27 PM
    Billyboy
    None
    HAHA, guilty as charged!!! Was tapping drum to loosen it and weight fell on floor. Was going to try and braze it back on but think I'll just let go. Thanks blkvoodoo and Jeffch.
  5. Aug 26, 2017 at 12:30 PM
    Bishop84
    Bishop84 Well-Known Member
    I've knocked off a hundred, never had a complaint. The amount of mud and rust that gets trapped in the lip negates whatever balancing it did when they were new.
  6. Aug 26, 2017 at 12:34 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    :cheers:
