Brake dust shields
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arthur106, Aug 20, 2024.
  1. Aug 20, 2024 at 11:13 PM
    arthur106
    arthur106 [OP] Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    Wanting to replace my dust shields, they’re rotted out pretty bad. How easy are they to remove without removing the hub? I was thinking of using a cutoff wheel to cut the new ones in half so I can get them bolted on without hub removal.
  2. Aug 20, 2024 at 11:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They bolt on with the 4 hub bolts. No way to get them on or off with out removing the hub.
    arthur106[OP] likes this.
  3. Aug 21, 2024 at 3:22 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Removing the hub isn't that hard. I have a BBK setup so I no longer have my dust shields:D
  4. Aug 21, 2024 at 3:49 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    You deleted the rock keepers? :rofl:
  5. Aug 21, 2024 at 3:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Watch a few Tacoma wheel bearing replacement videos. The dust shield is sandwiched between the wheel bearing and the spindle/knuckle using those four bolts.
    If the miles are high on your current wheel bearings, it would be a good opportunity to replace them, since the amount of work is exactly the same. SKF bearing-hub assy P/N BR930978 with 5 yr / 60,000 mi warranty: https://www.rockauto.com/en/moreinfo.php?pk=12676781&cc=1445180&pt=1636&jsn=1
