Brake dust
Discussion in '4th Gen. Tacomas (2024+)' started by Taco Ji, Mar 28, 2025.
  1. Mar 30, 2025 at 4:35 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea I noticed the same thing. Sitting at a little over 8K miles on mine and doesn't seem to be dusting that bad. Usually just pressure washing gets most of it off, but the inner barrels require more of a scrub, naturally.
    MJB4450[QUOTED] likes this.
  2. Mar 30, 2025 at 4:47 AM
    soggyBottom
    soggyBottom Well-Known Member
    It's possible the dealer put some shiny oily stuff on the wheels which is causing extra stuff to stick to it. Give it a good wash and see if that fixes it.
  3. Mar 30, 2025 at 6:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You saw that Car Car Nut video about Toyota factory pads vs. Toyota value pads sold at dealers? The factory pads are semi metallic and will dust more. The value pads (and Advics aftermarket pads) are ceramic and dust less.
  4. Mar 30, 2025 at 7:04 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Remove the pads and put some wheel bearing grease directly on the surface where it touches the rotor, that may help catch the dust before it gets on the wheels
  5. Mar 30, 2025 at 9:42 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I find this can cause some squealing though, strangely enough from inside the cab.
    TurboDA6 likes this.
  6. Mar 30, 2025 at 12:24 PM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    You're kidding I hope... Never add grease to brake pads or rotors (Ok on pins and clips). If you do, you have just jeopardize you stopping distance.
    SCSPerformance and Z7Xtreme like this.
  7. Mar 30, 2025 at 2:52 PM
    Taco Ji
    Taco Ji [OP] Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Yeah some of the comments here are wild.
    This isn’t my first new car. I’ve had cars with excessive brake dust coming off it. I was just wondering is it just me or is everyone else’s brake dust excessive too at first few hundred miles of ownership. I guess most people don’t even realized it or noticed it.
    Z7Xtreme likes this.
  8. Mar 30, 2025 at 3:03 PM
    roalddahl
    roalddahl Well-Known Member
    Wha? No, please, no, no, no.
    Delta09, Z7Xtreme and wilcam47 like this.
  9. Mar 30, 2025 at 3:26 PM
    soggyBottom
    Even if, it wouldn't work very long. The surface area of the grease would get saturated with dirt and become ineffective.
  10. Mar 30, 2025 at 3:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sarcasm guys, it's sarcasm
    Good lord
  11. Mar 30, 2025 at 4:03 PM
    Tacowrench
    Northern California
    You're reply read convincing, unfortunately for folks that may not know... And the ironic part is that I saw my neighbor lay large glob of grease on a rotor (I stopped him). I asked him why and he said, it came in the box and he thought it was to help break-in the pad. I couldn't believe my ears.
    TurboDA6 and Z7Xtreme like this.
  12. Mar 30, 2025 at 4:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Umm ok, well sorry for not treating a thread about brake dust more seriously
    I'll see myself out
    TurboDA6, VE7OSR and JoeMongo like this.
  13. Mar 30, 2025 at 5:36 PM
    Tacowrench
    Northern California
    No biggie...
  14. Mar 30, 2025 at 5:58 PM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    That was not a very smart thing to do. Especially for someone who goes around the site correcting peoples grammar.
  15. Mar 30, 2025 at 6:46 PM
    #35
    roalddahl
    You might want to work on your delivery.
  16. Mar 30, 2025 at 6:52 PM
    #36
    MGMDesertTaco
    OP could just drive around with it and ignore it like all the BMW drivers.
  17. Mar 31, 2025 at 4:04 AM
    #37
    Taco Ji
    New Jersey
    I’m well aware of excessive brake dust on BMW’s.
    Delta09 likes this.
  18. Mar 31, 2025 at 4:10 AM
    #38
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Honestly that's better than the Camry we have. It has black wheels and they looks absolutely gnarly after a couple weeks. It shows so much more than silver or gun-metal gray. I would think it would be the opposite o_O
  19. Mar 31, 2025 at 7:35 AM
    #39
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Some people should not be around tools.
  20. Mar 31, 2025 at 7:43 AM
    #40
    Tacowrench
    Northern California
    Funny, you are absolutely correct...
