Brake Failure!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Paps, Oct 4, 2021.
  1. Oct 4, 2021 at 5:22 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    It's hydraulic from the master cylinder to the caliper/wheel cylinder. There are no electronics involved in the hydraulic system.
    It's not entirely electronic. That is 100% false. The booster is electronic (I think) and the systems like ABS, collision avoidance, etc are electronically controlled. None of this is uncommon.
    shakerhood likes this.
  2. Oct 4, 2021 at 5:24 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    take it to dealer and see if they give you 1x courtesy repair. covid and all. call toyota customer service.
  3. Oct 4, 2021 at 5:24 PM
    Paps
    Paps [OP] Active Member
    I've blown brake lines and such in other old vehicles. Unless you don't take care of your vehicle and check old lines and cables or you piss somebody off and they cut your lines... they usually don't just fail.
  4. Oct 4, 2021 at 5:25 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The electronics are for the antilock you still should have breaking.
    the system is fail safe
  5. Oct 4, 2021 at 5:27 PM
    Paps
    That is my thinking. I have no issues with electronic assistance. Make that shit easier all day long! My issue is when a queertron goes crazy and now I'm driving with no braking power; that is absolutely completely unsat.
  6. Oct 4, 2021 at 5:28 PM
    Paps
    Don't take this personal.... but apparently it's not. lol.
  7. Oct 4, 2021 at 5:28 PM
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    I would start checking fuses related to brakes and abs.
    cryptolyme likes this.
  8. Oct 4, 2021 at 5:29 PM
    Paps
    Thanks for the thoughts, debates and replys everyone!
    I'm done in the garage for the day and a glass or two deep into some good bourbon. I'll look at getting a tow to a dealer tomorrow.
  9. Oct 4, 2021 at 5:29 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The brake booster which is what gives you the actual braking power is electronic. Yes the hydraulics and physical brakes aren't electronic, I thought that was a given and didn't need explanation. Without the electronic brake booster your brakes are nearly useless.
  10. Oct 4, 2021 at 5:29 PM
    Paps
    I'll go through again but 99.9% we checked them all, and all looked good.
  11. Oct 4, 2021 at 5:30 PM
    Paps
    (Not arguing with you) but I should still be able to stop the vehicle with zero electrical power at all.
  12. Oct 4, 2021 at 5:31 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    I suspect there is more to the failure than just one simple thing going wrong like a fuse, but I couldn't say much about troubleshooting without some info and schematics about the system. I would at least talk to the dealer, especially if you have reasonable miles on the truck for the age. It's not uncommon for them to help you out.
  13. Oct 4, 2021 at 5:31 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The brake system on all Tacomas is hydraulic and has various fail safes just like brake systems have had for 40 years.
    There are electronic controls and additional fail safes for them on some models, but in every Tacoma, the brakes will work with no power. You could disconnect the battery and the brakes will still work.
    What is different between some models is whether it has a conventional vacuum booster or an electronically-controlled hydraulic booster.
    Without a functioning brake booster, the brakes will still operate, but will require significantly more pedal force for the same stopping force.
    It does sound like your brake booster is malfunctioning from what you have described.
    Jeff
    tonered, Junkhead, Skydvrr and 7 others like this.
  14. Oct 4, 2021 at 5:33 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    You can. thats what the e-brake is for. I suspect that the difficulty to get the vehicle to stop with the brake pedal is because of the absence of booster assistance. Like trying to stop any car with power brakes when the engine stalls or a vac line pops off the booster.
  15. Oct 4, 2021 at 5:33 PM
    #35
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What are using to read codes?
    Try checking the following?
    Stop light switch
    STOP fuse
    STOP LO CTRL relay
    tonered likes this.
  16. Oct 4, 2021 at 5:33 PM
    #36
    Timmcc02
    Tim
    2017 TRD OR
    That’s why you never skip leg day
  17. Oct 4, 2021 at 5:34 PM
    #37
    Paps
    thanks. I'll triple check all my sensors. The brake pedal doesn't feel soft, but then, doesn't feel really stiff either. One of those, I never had an issue with brakes before this (34,000 miles with quiet a bit of those offroad) so I can't remember what it felt like for sure. lol
    tcjacado[QUOTED] likes this.
  18. Oct 4, 2021 at 5:34 PM
    #38
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    It is but at that point you are relying on just the physical compression of the brake fluid through the hydraulic advantage to provide clamping force with the electronic booster providing the real force. You can feel it work when you start your truck. With your foot pressing the brake at startup you can feel the pedal push back as the electronic system gets power and builds pressure.
    jmneill likes this.
  19. Oct 4, 2021 at 5:35 PM
    #39
    Paps
    truuuuuuuuueeeeeeeee
  20. Oct 4, 2021 at 5:37 PM
    #40
    Paps
    hmmm.... didn't think to check that.
    Just did, as it starts up there is no movement of the brake pedal...
