Brake Failure!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Paps, Oct 4, 2021.
  1. Oct 7, 2021 at 12:25 PM
    #141
    Paps
    Paps [OP] Active Member
    This may be the issue that I can't find an answer for, with people I know or my "awesome" googling skills.
    The bracket rubbed through the insulation of the wire into the brake booster. some small spark burns can be seen on the bracket, which is now cut and removed. Since the metal wire itself looks fine and undamaged, I simply rapped it in electrical tape to insulate it until a permanent repair can be done. Fuses have been check, all are good. Makes me worry it's internal damage. I'm grew up on carburetors and simple hydraulic systems, this shit is all new to me. My s2000 is a hell of a lot more mechanical than this truck.
  2. Oct 7, 2021 at 12:26 PM
    #142
    Paps
    From what i can find both on the fuse box covers themselves and the interwebs, the braking system has one fuse (ABS under the hood).
  3. Oct 7, 2021 at 12:50 PM
    #143
    GBR
    GBR Well-Known Member
    19 TRD OR
    You didn't "patch" it. You removed the short and reapplied insulation. Without looking more closely at it or testing the wire, nobody knows the electrical integrity of it.
    Edit: If the portion that rubbed through is suspect, it needs to be cut out and the wire spliced. Hopefully there is enough wire off the plug to do so. This would be the temporary fix.
    Someone that is electrically inclined and has the parts needs to repin the plug or find a replacement plug. This also assumes the existing run of wire is long enough. I don't know if this is tied into a larger harness. I would want to avoid having to change out an entire harness. Some people might be fine with having a splice in this wire, but considering how critical it is, I personally wouldn't.
    Kev250R and Chew like this.
  4. Oct 7, 2021 at 12:53 PM
    #144
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    As usual.
  5. Oct 7, 2021 at 12:54 PM
    #145
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You checked the fuses under the dash too yeah?
    SR-71A and shakerhood like this.
  6. Oct 7, 2021 at 1:01 PM
    #146
    GBR
    19 TRD OR
    I'm guessing a fuse did blow. If you have evidence of arcing, you had a short. It likely blew a fuse and you just haven't found it.
    SR-71A and Paps[OP] like this.
  7. Oct 7, 2021 at 1:04 PM
    #147
    Paps
    yup, all good.
  8. Oct 7, 2021 at 1:07 PM
    #148
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Interesting.
    Paps[QUOTED][OP] likes this.
  9. Oct 7, 2021 at 1:08 PM
    #149
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    There’s atleast 2 abs fuses under the hood
  10. Oct 7, 2021 at 1:12 PM
    #150
    Paps
    fuck me I'm blind.....
    I found the 30A ABS fuse and that's because apparently I'm blind as a damn bat. Just found the 50A (two whole fuses away) that is blown.
    LMAO, as I search for more, are there any? external-content.duckduckgo.com.jpg
    RedWings44, SR-71A and daks like this.
  11. Oct 7, 2021 at 1:13 PM
    #151
    Paps
    I'm a frustrated blind idiot!
    Thanks!
    tcjacado likes this.
  12. Oct 7, 2021 at 1:13 PM
    #152
    Timmcc02
    Tim
    2017 TRD OR
    You found a blown fuse then that’s your problem. But if your wire isn’t fixed properly you will blow a new fuse you put in there
    Chew and Paps[OP] like this.
  13. Oct 7, 2021 at 1:16 PM
    #153
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    I had some good luck finding a connector here after one of my connectors in my Waverunner corroded: https://www.corsa-technic.com/
    But I agree with you. For a failure like this, I would likely go with a whole harness if it's sliced through enough.
    ca08tacoma and Paps[OP] like this.
  14. Oct 7, 2021 at 1:16 PM
    #154
    Paps
    Yes. I'll pick up some extra fuses and then pull out my ohm meter and reteach myself how to test this wire. SHTF right now so money is tight, trying to find the correct fix but also spend as little as possible.
    Thanks!
  15. Oct 7, 2021 at 1:17 PM
    #155
    Paps
    It only sliced through the insulation. Would this really require a whole new harness?
  16. Oct 7, 2021 at 1:18 PM
    #156
    Paps
    though I missed one under the hood. ABS 50A is blown.
    Skydvrr[QUOTED] likes this.
  17. Oct 7, 2021 at 1:18 PM
    #157
    dr4g1116
    I don't know the gauge of that specific wire, but it clearly made contact with some metal hence the arc. Maybe just one strand of copper. It's likely fine, the way you describe it but I would have an electrical expert look at something that important.
  18. Oct 7, 2021 at 1:19 PM
    #158
    Timmcc02
    Tim
    2017 TRD OR
    No, but you should cut out that section of wire as it’s likely burnt where it shorted. You could then get a new pin for that connector for that wire and splice in a piece of wire with new pin attached into that connector.
  19. Oct 7, 2021 at 1:19 PM
    #159
    Skydvrr
    Nick
    YMH
    Black '17 OR
    De-pin & heat shrink? Depends on how bad the wire is
  20. Oct 7, 2021 at 1:20 PM
    #160
    Puckbag34
    Puckbag34 Well-Known Member
    No longer second guessing buying that Jackery...
