Brake Feeling Not Smooth (TRD off road)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mothertrucker, Nov 25, 2015.
  1. Nov 25, 2015 at 10:27 PM
    Mothertrucker
    Mothertrucker [OP] Member
    Houston
    When I apply the brakes, I sometimes get a slight feedback from the pedal to where it doesn't feel smooth. The feedback feels as if ABS kicked in very softly and for a split second.
    I drive the TRD off road.
    I have a feeling that this is normal, but I just want to make sure. Is this due to the hydro booster? This might be a dumb question but just wanted to ask. Thanks!
    bubbakingaroo and TFly like this.
  2. Nov 26, 2015 at 5:11 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Maybe still breaking in? How many miles you have on it?
  3. Nov 26, 2015 at 5:36 AM
    16tacomaOR
    16tacomaOR Well-Known Member
    Sam
    16 Tacoma OR 4x4
    My OR does the exact thing, when I apply brakes it feels just like abs as you described, of all the Tacomas I have driven (4-5) they all did it, I'm not saying its right, but it's common
    bubbakingaroo likes this.
  4. Nov 26, 2015 at 6:12 AM
    Mothertrucker
    Houston
    I have about 250 miles.
    I think it has something to do with the brake booster because it will occur even at a complete stop in Neutral. I just don't know for sure. I only driven vehicles with vacuum brake boosters. Or, it could be something differently and I'm wrong lol
    Ok well I'm glad I'm not the only one! This makes me feel better.
  5. Nov 26, 2015 at 6:28 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Sometimes? Like when you brake short & suddenly; not a nice gradual stop?
    Me too; sounds normal.
    See page 264 of your manual.
    16tacomaOR likes this.
  6. Nov 26, 2015 at 7:07 AM
    tacomanamedolga
    tacomanamedolga Well-Known Member
    SeviervilleTn
    2015 trd offroad
    Mine does it too. I can be in park, with parking brake on, push the brake pedal, and get a click.
    G-Dawgg and Mothertrucker[OP] like this.
  7. Nov 26, 2015 at 8:06 AM
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Mine does it as well, but when braking at speeds under 25 mph. Dealer said the other trucks on the lot did it as well so it was "normal" Don't know if I buy that, but doesn't seem like that big of a deal as it's very minor.
  8. Nov 26, 2015 at 8:25 AM
    cpcoldsmoke
    cpcoldsmoke Well-Known Member
    Washington
    '16 DCSB TRDOR
    Yep, I have this exact issue. And only at lower speeds as said above. Got about 1600 miles on it, just got Blizzaks, and still has that ABS feel at low speed braking. It's annoying for city driving, let's hope there is a fix.
    Mothertrucker[OP] and 16tacomaOR like this.
  9. Nov 26, 2015 at 8:26 AM
    16tacomaOR
    Sam
    16 Tacoma OR 4x4
    I believe there will be fixes for all the little quirks we are experiencing, 1st year truck is bound to have a few issues.
  10. Nov 26, 2015 at 12:35 PM
    Mothertrucker
    Houston
    It's a normal gradual stop on dry cement road - not short or sudden stop. It doesn't happen each time.
    Page 264 of the manual talks about brake assist. It states that brake assist activates when the system detects a panic stop situation.
    I'm wondering if this is just the passive nature of a hydro booster brake system (opposed to a vacuum). I don't think it has to do anything with the rotors, calipers, etc. because it occurs in neutral at a stand still.
  11. Nov 27, 2015 at 9:55 AM
    Mothertrucker
    Houston
    If anyone finds anything about this, can you please share?
    I'm planning on taking my truck back to the dealer for another warranty issue so I'll ask about this too.
  12. Nov 27, 2015 at 5:25 PM
    mjones1970
    mjones1970 Well-Known Member
    I had that issue when I bought my new 2011 TRD off road. I took it n and they discovered warped Roters and fix the problem.
  13. Nov 27, 2015 at 7:39 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    I picked up my 2016 Tacoma 4x4 Off Road today and don't notice anything abnormal about the brakes. However I had a 2005 4Runner Limited V8 AWD before with the hydroboost brakes so maybe I'm used to them. I think the brakes in this truck feel fantastic. It stops very well, the brakes grab right at the top of the pedal and it's easy to modulate. By far the best brakes of any of the trucks I've owned (F150's, Ram's, Tundra and other Tacos).
    Mothertrucker[OP] likes this.
  14. Feb 19, 2016 at 1:31 PM
    desertstriker8
    desertstriker8 New Member
    Kyle
    2016 Tacoma TRD OR
    Mothertrucker iv seen its been a while sense you have posted. I just picked up my 2016 TRD OR, and I'm noticing that same slight vibration or pulsing feeling in the brake pedal when either braking at lower speeds or even when the car is parked and running and I put the brake down to the floor. Have you every found out an answer as to what's causing this or is it normal behavior?
    The Dealership is telling me its to do with a spring and pad behind the pedal, which seems to make no sense at all. It almost feels more like something electronic is engaging or turning on and as you stated its not as strong as ABS would feel but it has a quick pulsating in the pedal. Defiantly doesn't feel right.
  15. Feb 19, 2016 at 6:52 PM
    Mothertrucker
    Houston
    I have not found out why it does that. I havent had the time to go to the dealership but I plan on going this month. If I find anything out, I'll keep you and everyone posted.
    Based on what you said, your symptoms sounds identical. I don't think it has to do with anything with the "spring or pad" either (but who knows until it's confirmed).
    What's weird is that it's intermittent. Try pressing the brakes while the car is stopped and in nuetral. You'll probably experience the same result (as if you were slowing to a stop). Then the second or third time you press it, it might not happen.
    I want a written statement from the dealership or Toyota saying it's ok. Perhaps it really is a normal behavior.
  16. Feb 20, 2016 at 5:25 AM
    desertstriker8
    Kyle
    2016 Tacoma TRD OR
    Yeah I agree with what you were saying, for me if the car is parked and running it will do the pulsate on the brake every other time I press the pedal down. Also I can see it obviously taking power to run, and making my lights dim. I'm at the dealership now and their head tech just took it for a ride with me and told me it's defiantly not right, he's going to look at it and try and fix on his own, but he said he may have to wait until Monday and reach out to the westcoast. I'll update once I'm leaving the dealership.
    Update: just had the tech come back he can't find anything wrong, he's telling me it's defiantly working as it should but the vibration in the pedal he's not sure if it should be able to be felt like it is in mine. He's going to reach out to TOYOTA on the west coast and give me a ring at some point on Monday. He said he doesn't have another one here that has the same options as mine with the crawl control so he can't compare. I feel like I'm going to start to get the run around :(
  17. Feb 20, 2016 at 6:58 AM
    viking15
    viking15 Well-Known Member
    Joe
    Leave the truck there until they fix it and have them provide you a loaner
  18. Feb 20, 2016 at 10:52 AM
    MarkinWestMich
    MarkinWestMich Member
    2016 Tacoma TRD Off Road
    I've got about 750mi on mine right now. It has always done this with "moderate" braking,...just the lightest bit of rapid pulsation in the brake pedal. It brakes just fine, it just feels a little strange on your foot. "Light" braking,...smooth, no pulsation. Never had to hard brake it yet.
  19. Feb 20, 2016 at 11:34 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Here we go with this again... :popcorn:
  20. Feb 20, 2016 at 11:45 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    It's the electric motor pumping up on the brake booster
    Tharris242 likes this.
