Brake Feeling Not Smooth (TRD off road)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mothertrucker, Nov 25, 2015.
  1. Jun 8, 2016 at 8:25 AM
    #41
    ThXinc
    ThXinc Blue Thunder
    Dallas / Fort Worth
    2016 Blazing Blue TRD 4x4
    3" OME 885, Bilstein 5100s, Add-a-Leaf, BFG 285/75/17, Vision Fury Wheels, T-Rex Grill, Magnum Steps, ARE Outland Cap, Bed slide, roof rack, Bushwacker fenders, 5.29 diff
    Yes. Mine are much more sensitive than I am used to...sometimes just a little effort and the nose is down and tires are barkin'.
  2. Jun 8, 2016 at 8:44 AM
    #42
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2012 DCSB TRD OR
    Mine are the same way, I've had the truck a few weeks and I still trying to get used to it.
  3. Jun 8, 2016 at 11:07 AM
    #43
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I came from two European sports cars so these brakes barely felt like they were working when I first started driving this thing.
    The brake pulsating I am talking about can be induced by pumping the brake while parked.
  4. Jul 29, 2016 at 12:17 PM
    #44
    davidsp101
    davidsp101 Well-Known Member
    David
    Columbia, SC
    2017 TRD OR 4x4
    OP, did this happen right before you came to a stop? I only experience it right as I'm coming to a stop and it drives me nuts. Steady and consistent pressure on the brakes and all of a sudden you feel like you're gonna be thrown through the windshield. They've cleaned the rear drums of any "dust" but still hasn't fixed it. Curious if anyone else is experiencing this and what dealers have done to fix the problem!
  5. Jul 29, 2016 at 12:20 PM
    #45
    urchim
    urchim Well-Known Member
    Tacoma 2016 TRD Offroad Inferno
    Does this occur at slow speeds, like a slight drive vibration or driving through washboard, if yes, then you are not alone, mine does it to around 22mph down to 15mph, u can test it urself by just coasting below those speeds.
    no solution is seen or at least that i found and dealer is still researching mine.
  6. Jul 29, 2016 at 12:35 PM
    #46
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yep I call it the brake queef. Mine are pretty damn sensitive.
    I'mTheDude[QUOTED] and fdbyrne like this.
  7. Dec 8, 2016 at 6:43 AM
    #47
    oldskoolsteve
    oldskoolsteve Member
    Steve-o
    WestCoastVanIsland
    2015 TRD off-road access cab
    I drive a 2015 Gen 2 OR and have been dealing with this "pulse" with the dealership for over a year.
    I have now opened a case with Toyota Canada and the investigation is ongoing.
    The head tech of the dealership has stated its normal as the pump actuates.
    It should happen on every 5th pump and more commonly at low speeds.
    I'm a red seal certified auto tech and by no means believe this is normal.
    The driver should not feel this much feedback in the pedal. I understand the hydroboost system and its advantages but it seems to me a fail in design to have spring popping feel in the pedal as strong as occurs. it makes slow and city driving immensely annoying.
    I researched for a year before buying this truck and Im happy in every other regard.
    I truly hope a correction is in the future as this is a huge disappointment in an otherwise superior product.
  8. Mar 4, 2017 at 8:33 PM
    #48
    smtaco
    smtaco New Member
    2017 TRD OR 4x4 DCSB
    Any updates from anyone? I just purchased mine a week ago and noticed this annoying pulse issue. Mine occurs every other attempt to brake. No bite either in my brakes compared to what others are describing.
    bubbakingaroo likes this.
  9. Mar 4, 2017 at 10:57 PM
    #49
    Nexusix
    Nexusix Well-Known Member
    2017 Toyota Tacoma TRD Offroad 4x4
    I can attest to this as well, I've got about 3500 miles on my '17 OR and recently noticed this vibration which hadn't occurred before, some days it doesn't even happen. I doubt its warped rotors. I feels almost electronic, like a brake booster/abs related issue. It always happens when I come to a slow stop, its like a strong cell phone vibration feel to the foot for about 2-3 seconds, you can even hear it slightly. If it is normal, I wonder if it has any long term damaging affect on the braking system.
  10. Mar 4, 2017 at 11:30 PM
    #50
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    Guys... like two or three people have already said:
    The off-road has an electric brake booster that pressurized the brake fluid instead of using a vacuum assist. This is what makes the MTS/CRAWL possible on the off-road and why no other trims have it. You are feeling the electric motor pressurizing the fluid.
    If you don't have an OR, then you have a problem.
    EDIT: the Pro uses the same brake booster as the OR.
  11. Mar 5, 2017 at 3:45 AM
    #51
    PeteK
    PeteK Well-Known Member
    Brockton, MA
    2017 Cement Truck
    Happens on the Pro too. I get it at the same intersection every morning.
    Tig3r_Bit likes this.
  12. Mar 5, 2017 at 7:12 AM
    #52
    smtaco
    smtaco New Member
    I wonder though if the frequency i feel the pulse is normal. Literally every other time i step on the brake which makes me think it's not normal. I don't have any bite on my brakes that others have commented on, whereas mine brakes smoothly but requires more force.
    Also not having HAC was a bummer, another unique trait of TRD OR/PRO, b/c of crawl control?
  13. Mar 5, 2017 at 10:14 AM
    #53
    Tharris242
    Houston, TX
    Oh yeah, forgot about the Pro. I'll update my post.
  14. Mar 5, 2017 at 1:35 PM
    #54
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Sounds like a 3rd world Off Road problem....!!!!:rofl:
    Doesn't work ON ROAD...!!!
  15. Mar 5, 2017 at 3:01 PM
    #55
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    I don't have any of the issues mentioned here. My brakes are extremely responsive but I came from an Acura TSX which had amazing brakes, especially after I changed out the pads, rotors and bled the system. The Stoptech upgrade I did on that car made the brakes super touchy as well.
  16. Mar 5, 2017 at 3:12 PM
    #56
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I'm having the same problems to.
  17. Mar 5, 2017 at 3:28 PM
    #57
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    It's the accumulator pump spinning up. Normal.
    Park the truck, depress the brake ordeal 2-3 times and you'll feel the pedal sensation and you can hear the pump if you listen closely
    bubbakingaroo and Tig3r_Bit like this.
  18. Mar 6, 2017 at 10:28 PM
    #58
    oldskoolsteve
    Steve-o
    WestCoastVanIsland
    The investigation with Toyota continues.
    They ask me to leave the truck for a day, and do some tests. I haven't heard anything about anything.
    As much as I'm getting used to it, I stand by the fact that its not acceptable for what should be a superior product.
    I'm also noticing increased under-braking or over-braking at times dependent on different scenarios.
    Face the facts.
    Its a brake by wire/computer- system and they didn't figure it all out correctly.
  19. Mar 6, 2017 at 10:51 PM
    #59
    -p-
    -p- Well-Known Member
    Dallas
    2016 Tacoma TRD OR
    How are none of you reading that this is normal as the OR has an electric booster vs. vaccum in other models to help with slow (low vacuum conditions present when offroad) that has been discussed endlessly?
    Jesus FC listen(read), think, and then search. Do we need another thread?
  20. Mar 7, 2017 at 9:26 PM
    #60
    oldskoolsteve
    Steve-o
    WestCoastVanIsland
    go f*ck yourself, expert.
    I'm a red seal mechanic.
    I know what Hydro boost is.
    GM can make Hydro-boost that does not have this poor pedal feel.
    Eat a dick.
    TFly likes this.
