Brake Feeling Not Smooth (TRD off road)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mothertrucker, Nov 25, 2015.
  1. Mar 7, 2017 at 9:32 PM
    #61
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    :popcorn:well this just got entertaining
  2. Mar 8, 2017 at 9:08 AM
    #62
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just because GM's doesn't have that feel doesn't mean Toyota's is not working. The feedback is normal.
  3. Mar 8, 2017 at 9:43 AM
    #63
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Considering this thread was started in Nov. 2015......or did you not bother to read, think and search?
  4. Mar 8, 2017 at 9:56 AM
    #64
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Not really. The brakes will still work even if the accumulator pump goes out, it'll just take more pedal pressure.
    But yeah, it's a weird feeling and all but you get used to it. The Land Cruiser has/had the same kind of setup and there's NO noticeable pedal feel when the pump kicks on...but that's like $70-80k range. So I believe Toyota knows how to do it right but probably accepted the "less than ideal" pedal feel from cheaper components to introduce these spiffy features like CRAWL control and ATRAC on a $35 truck.
    If you don't want to accept it as normal, keep fighting a losing battle or sell the truck and buy something else.
  5. Mar 8, 2017 at 2:13 PM
    #65
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    Whoa, whoa , whoa... Mr red seal mechanic. Are you sure you know what hydroboost is? Hydroboost uses the power steering pump for hydraulic pressure. Tacoma is electric... completely different systems.
  6. Mar 8, 2017 at 2:18 PM
    #66
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    get out the 3rd gen subforum with ya old ass 2015 :poking:
    smitty99 likes this.
  7. Mar 9, 2017 at 8:51 AM
    #67
    HFDFF
    HFDFF Well-Known Member
    My brakes at 2900 miles feel great.
  8. Mar 9, 2017 at 11:41 AM
    #68
    smtaco
    smtaco New Member
    2017 TRD OR 4x4 DCSB
    went to a dealership and had their master tech guy with me testing out my truck vs. 2 other brand new TRD OR. The brand new ones, barely had any noticeable pulse when depressing the brake pedal vs. mine which was strong. Of course the tech guy said i can't tell the difference. Unbelievable, guess that's Toyota for you.
    shakerhood likes this.
  9. May 23, 2017 at 2:48 PM
    #69
    saltymaui
    saltymaui Member
    I have the same slight vibration issue with braking. Toyota says it is normal but it shouldn't vibrate. Anyone get this issue fixed? Why would the Hydro Boost vibrate/flutter as compared to non-Hydro Boost brakes?
  10. May 23, 2017 at 3:08 PM
    #70
    Tharris242
    Houston, TX
    It is normal.
    Most brake boosters run off a vacuum assist. Pro and Off Road are different. They use an electric pump that runs on-demand. You feel it because it is probably a positive displacement type of pump... like a fast little bicycle pump.
    It is normal.
    Edit: I was unecessarily talking about hydro-boost (that runs off power steering pump).
    Tig3r_Bit likes this.
  11. Dec 19, 2017 at 7:37 PM
    #71
    Lando883
    Lando883 Well-Known Member
    Lando
    SoCal
    2021 Tacoma TRD OR
    This has happened to me on my 2017 OR. A little over 11K now, but this has occurred on sudden stops from 30mph and even at 5-10mph. The low speeds have made me worried thinking the brakes were ba, but this thread summarizes it well. Thanks y’all!
  12. Apr 25, 2018 at 4:58 AM
    #72
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    2018 TRD OFF ROAD. When I apply brake I hear like a vacuum or something running? Not sure. Might b normal?
  13. Apr 25, 2018 at 5:57 AM
    #73
    Tig3r_Bit
    2018 TRD OR 4x4
  14. Apr 25, 2018 at 6:37 AM
    #74
    Tharris242
    Houston, TX
    Well, the electric pump that provides the hydraulic boost does make noise and vibrations for up to a few seconds; so, probably normal... especially if it coincides with the pedal vibes.
    Tig3r_Bit[QUOTED] likes this.
  15. Apr 25, 2018 at 7:13 AM
    #75
    Tig3r_Bit
    2018 TRD OR 4x4
    Tharris242 yes! It goes off for a second or so and shuts off. Is this normal for all new Tacomas? Thanks
  16. Apr 25, 2018 at 11:25 AM
    #76
    Tharris242
    Houston, TX
    Normal for all Off-Road and Pro.
    The electric booster is apparently necessary to enable crawl control... I guess the vacuum booster can't keep up with all the crawling madness.
    The bonus is that it can give you a brake boost even if the engine is not running (ignition on) unlike vacuum boost. Maybe you want to roll a little way down an incline without cranking it up... or maybe you're being towed because your engine won't run (still need battery power, though).
  17. May 8, 2018 at 3:21 AM
    #77
    Marconis
    Marconis Well-Known Member
    New York
    2017 SR5 DCSB 4X4
    The same exact feeling in my brake pedal randomly started happening on the highway yesterday and caught me off guard. It's happening consistently now and my truck is currently with the dealer, dropped it off right away last night. I have an SR5, though. I'm sure they will tell me today that they cannot replicate it and/or it is normal.
  18. May 8, 2018 at 11:13 AM
    #78
    Marconis
    New York
    2017 SR5 DCSB 4X4
    Got a call back and they said two separate technicians stated condition could not be replicated and all is normal. Will see when I pick up my truck
  19. May 8, 2018 at 11:14 AM
    #79
    Tig3r_Bit
    2018 TRD OR 4x4
    That's crazy. Maybe it's always been there and u just notice it @Marconis ? Keep us updated.
  20. May 8, 2018 at 11:18 AM
    #80
    Marconis
    New York
    2017 SR5 DCSB 4X4
    Definitely has not been . I was talking to my wife on my Bluetooth and while she was talking I got startled because my brake pedal suddenly felt different and felt like it was vibrating when lightly pressed. I had to hang up the call to see what was up and I tested it for another 35 minutes on my way home. For the first half inch of pressing it's like there is a cell phone vibrating or something slipping under my boot , then it feels loose and weird .
