Brake Fluid? Castrol LMA synthetic okay to use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by stinkyspice, May 15, 2013.
  1. May 15, 2013 at 1:17 AM
    stinkyspice
    stinkyspice [OP] Well-Known Member
    ive recently got the wheelers ss brake lines all around was planning on changing them all this week. was wandering about the fluid i have a huge ass bottle of castrol lma synthetic brake fluid sitting in the garaged. is it alright to use this fluid in the tacoma. its a 03 DC. is it alright to just mix with the fluid in there when im bleeding the brakes? sorry if a dumb question lol. dont know much about bleeding brakes....
    thanks for any help
  2. May 15, 2013 at 6:11 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I would stick to conventional brake fluid.. Synthetic fluid doesn't absorb water like regular does, therefore when moisture enters the system it will sit in the lines and cause corrosion. The conventional fluid would absorb the moisture, then after its shot you flush it out and everything's awesome. My vote says get some conventional and do a brake flush front and back
  3. May 15, 2013 at 8:07 AM
    swdockter
    swdockter Well-Known Member
    Northwest Burbs, IL
    2" lift, 5100s, AAL, K&N, Deck Plate, 375K and counting
    If you go to dot 5 (silicone), you have to complexly flush your brake lines and calipers...ever little bit of dot 3/4 fluid has to be cleaned out. It's a big hassle to do it right.
  4. May 15, 2013 at 8:58 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    If it's a sealed bottle, I'd go for it. Since it absorbs less moisture, you won't have to flush/bleed as often. Just make sure to bleed all the old out.
  5. May 15, 2013 at 11:22 AM
    stinkyspice
    thats where im confused it doesnt say dot 5 anywhere.. just says synthetic. unless synthetic is dot 5?
  6. May 15, 2013 at 11:30 AM
    swdockter
    Northwest Burbs, IL
    Dot 5 is silicone...should be purple in color to. That is how they indicate the difference. It is NOT compatible with Dot 3 or 4.
  7. May 15, 2013 at 11:55 AM
    Robnik
    Rob
    Greenacres, Florida
  8. May 15, 2013 at 4:42 PM
    stinkyspice
    Cool thanks for the help would. I found some more info saying that the castrol lma is in its own class it's not a dot 5.1 nor a 4 but is comparable with dot 3 and 4.
    Here is the link to the article if anybody is interested.
    http://www.gomog.com/allmorgan/brakefluid.html
  9. May 15, 2013 at 6:15 PM
    stinkyspice
    what size flare nut wrenches would i need is it a 10mm and a 17 mm? its an 03 double cab
