Brake fluid change
Discussion in 'Technical Chat' started by coffeesnob, Jul 7, 2010.
  1. Jul 7, 2010 at 12:22 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Anyone on here change / flush their brake fluid on a regular basis? If so how often? I have read/heard most people never do this at all.
  2. Jul 7, 2010 at 12:32 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Stryker420, Msujeff and Djtiti like this.
  3. Jul 7, 2010 at 12:52 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    that looks cool! I know my camry needs this!
  4. Jul 7, 2010 at 12:59 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I've never flushed brake fluid, but I know my Honda Civic owners manual says every 3 years, regardless of mileage. I live in a very dry climate in Nevada, but if I lived where it was more humid, I would probably flush it every few years to get any moisture out of the system. JMO.
  5. Jul 7, 2010 at 1:01 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    I have never flushed a brake system before. I have owned my camry for 9 yrs now, longest I have ever owned one car. never flushed it, guess I should.
  6. Jul 7, 2010 at 2:47 PM
    coffeesnob
    VA
    :confused:
    I never really ever thought about it, until a mechanic told me my wifes accord needs it done. The thing has almost 150,000 miles on it and the brakes still feel good and tight. I am going to do it though hopefully we'll get another 150,000 miles out of it. My wife loves that car more than me, but I think she feels the same about me and my Tacoma:eek:
  7. Jul 7, 2010 at 3:21 PM
    bearing01
    bearing01 Member
    San Diego
    4x4 TRD V6 MT
    You're supposed to flush brake fluid every 2 years. I aim for every 4 years.
    Msujeff likes this.
  8. Jul 7, 2010 at 3:24 PM
    afd23a
    The Dynamo of Dixie
    The power bleeder from motive products is pretty easy to use if you want to do it yourself. It costs about as much as getting a professional flush done, except you get to use it again next time.
  9. Jul 7, 2010 at 4:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The only time I've ever flushed the system, was when I was installing new lines, new rotors and had the lines disconnected.
    Unless the vehicle is older.... the fluid is contaminated ...or you're bored... go 4 it.
  10. Jul 8, 2010 at 6:52 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    It's worthwhile every few years at least, especially if the manufacturer recommends it. I've only done it once. Had an older Accord, decided to get that done, because of a rusted out brake line on another old vehicle, that one actually broke the line while I was driving it, that's when I understood the value of two separate braking systems, I was able to still drive, although with a lot of care due to much reduced braking effect. Anyway, back to the Accord, I took it to a local Monroe Muffler place, stressed repeatedly (at least 3 times) that I wanted the brake fluid completely replaced, i.e., flushed, and not just the brakes bled. Repeatedly. And then when it was done and I was paying, I asked again, "you did do a complete flush, right?" and every time I was assured that a complete flush would be done, and had been done. A short while later, I notice a rear wheel cylinder is leaking slightly. So I replaced it, went to bleed the brakes, and there is all this very dirty fluid coming out. So I flushed the damn stuff myself, and it was very dirty, and Monroe Muffler in Vienna, WV is a bunch of fermunda-head liars and thieves. Another reason to do it yourself, just like an oil change. As dirty as that fluid was, I have been a believer of brake fluid flushing ever since. It is the same as bleeding, just takes a little longer, have to pump more fluid through until it runs clean, no big deal.
    Msujeff likes this.
  11. Jul 8, 2010 at 6:55 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    honda's or any car should be done every 3 years or 45k
  12. Oct 16, 2015 at 9:38 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Do you know which power bleeder is needed? Motive sells a bunch of them. Was thinking of just grabbing the cheapest one I could find but not sure if I need an adapter.
    http://motiveproducts.3dcartstores.com/
    http://www.amazon.com/s/ref=sr_pg_1?srs=2596863011&rh=i:specialty-aps&ie=UTF8&qid=1445056641
  13. Oct 17, 2015 at 10:25 AM
    afd23a
    The Dynamo of Dixie
  14. Oct 17, 2015 at 1:10 PM
    beavis87
    El Paso
    '10 Silver TRD OR
