Brake fluid flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Nov 17, 2019.
  1. Nov 17, 2019 at 6:13 PM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys, I did a search but couldn't find the answer. I was wondering at what miles do you flush the brake fluid at ? I have a 2011 prerunner TRD with 45000 miles.
  2. Nov 17, 2019 at 7:00 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I have 130k on mine. Still have original brakes. I plan to replace everything and do a flush in the spring when it is warm and I can take the time to deal with it.
  3. Nov 17, 2019 at 7:04 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Recommendations vary. Some will say every 3 years, some never do it.
    I flush every 5, but I am a maintenance whore.
  4. Nov 17, 2019 at 7:11 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    The fluid near the calipers breaks down over time due to heat. Moisture also eventually seeps in. I live in the desert SW and change it every five years even if it looks clear in the master cylinder as that may not be the case at the wheels. Fresh fluid will also extend the life of the rubber components in the brake system.
    PzTank likes this.
  5. Nov 17, 2019 at 7:13 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    I flush my brake fluid every other year.
    Rambo54 likes this.
  6. Nov 17, 2019 at 7:18 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Symptoms can show up over time because of the brake fluid breaking down do to moisture and heat transfer....depending on climate and road conditions style of driving. Cant hurt anything buy bleeding the breaks on a regular basis....Brake fluid is one of cheapest items to purchase - flush often. Easy to do....
  7. Nov 18, 2019 at 3:58 AM
    tacoma guy
    Joe
    Phoenix Az.
    All very good advice. I am getting lose to needing front brakes ao I we definitely flush it at that time. Thank you all for the replys most helpful !
    Rambo54 likes this.
  8. Nov 18, 2019 at 12:44 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Why encourage one or some of the eight front pistons to stick? Change the fluid during the front brake job (ie 3-4 years). Prestone Dot4 is a very good synthetic and cheap.
  9. Nov 18, 2019 at 1:21 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I flush mine every couple years. I have a TRD Sport so this doesn't help me, but the magic brakes on the TRD OR make that one super easy to flush with one person.
  10. Nov 18, 2019 at 1:23 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I do every 2-3 years.
