Brake fluid leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bowhunter74, Nov 8, 2022.
  1. Nov 8, 2022 at 8:02 AM
    Bowhunter74
    Bowhunter74 [OP] Well-Known Member
    I have a brake fluid leak at my front driver's side. It looks to be coming from the coiled metal tubing which drips onto the UCA. It's scaled and looks crispy.
    What is this part? Is it an easy fix?
    Thanks.
  2. Nov 8, 2022 at 8:14 AM
    Bishop84
    Bishop84 Well-Known Member
    It can be a bear. Honestly if it’s rusted the rest of the system is rusted. I would take it a licensed shop to get it inspected and repaired properly.
    If it’s leaking there, other issues might be lying in wake as well .
    plus you can damage the coupler it’s mated to if not careful causing a snowball effect.
    They sell the coiled line from Toyota. I just urge caution with jobs like this.
    fb40dash5 and Too Stroked like this.
  3. Nov 8, 2022 at 8:18 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Are you 100% sure it's brake fluid and not some other fluid? Since a leak anywhere in your braking system is a critical safety issue, I'd suggest skipping an internet opinion fest and instead take the truck immediately to a trusted mechanic for evaluation and repair. If it is a brake line going bad, it may fail catastrophically at any time and leave you with little or no braking. That said, it doesn't matter if it's an easy or complicated fix, it needs to be fixed immediately.
    fb40dash5 likes this.
  4. Nov 8, 2022 at 8:20 AM
    Bowhunter74
    I'm assuming brake fluid because my brake light came on yesterday. It also came on a couple months ago, and topping off the reservoir turned the light off.
