Brake fluid leak...
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Jun 6, 2025.
  1. Jun 6, 2025 at 2:36 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Hey everyone
    I've got an 02' V6 4wd that sprung a leak in the brake line up by the passenger wheel hub. When I press the brake pedal down there is a significant pouring of brake fluid coming out of the brake caliper housing. I haven't taken it apart to diagnose it because it's on the side of the road..
    I just need to limp it home so I can dig into it .
    I'm wondering if I can pinch the line with a pair of vice grips to isolate the leak so I can get it home.
    Forgive my ignorance when it comes to brakes.. thank you for any good advice!!
  2. Jun 6, 2025 at 3:09 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    pinching the line with vise grips/locking pliers/C clamp (use some sort of cushion) is OK way to limp home
    big issue is how much B fluid in your master cylinder res. if fluid lvl empties out in MC res....you will have air in lines and at any moment could lose all brakes
    keep everyone posted
  3. Jun 6, 2025 at 4:33 PM
    bodhi armor
    Joshua
    East TX
    Thanks for the advice. I'll likely use a bicycle inner tube to protect the line.
    And yes I'll definitely double check brake fluid level.
    I had an issue where my coilover rod disconnected from the lower mounting eye while driving. Thankfully I was only doing about 25 mph and was able to immediately pull into a parking spot. I got my coilover changed out, then while checking for additional damage discovered the leak when applying pressure to the brakes.
    Thanks again
    ControlCar[QUOTED] likes this.
  4. Jun 6, 2025 at 9:36 PM
    02hilux
    Planet: EARTH
    Please DO NOT do what the other person suggested. That’s probably by far the worst and dangerous suggestion someone can offer. If the brake fluid is leaking and you can’t fix the issue, tow it home. It’s cheaper than causing an accident and potentially killing someone’s because you thought it was SAFE to pinch the brake hose.
  5. Jun 7, 2025 at 7:22 AM
    bodhi armor
    Joshua
    East TX
    Safe is a relative term .
    I only need to drive about 5 miles of tx back roads going 20 mph max to get it home, if It required driving thru a city, or on the highway I would never attempt something like that.
    Thank you for the word of caution!
    ControlCar likes this.
  6. Jun 7, 2025 at 7:26 AM
    bodhi armor
    Joshua
    East TX
    I'm considering doing a "reverse flat tow".
    I had the idea last night of hooking my wife's truck to my truck with a tow strap to get it home. Instead of her truck in front pulling mine, I would be in front and she would be driving behind me, if something happens where I lose brakes she can use her brakes to stop my truck .
    Has anyone ever tried that? I think it's a sound theory..
    ChinoXL likes this.
  7. Jun 7, 2025 at 8:15 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    You still have an E brake thats perfectly functional...
    Also you still have regular brakes regardless if you lost all fluid & pedal drops to the floor....
    They just dont feel as we're accustom to...
    That being said, I can not assess your driving skills.....
    ControlCar and bodhi armor[OP] like this.
  8. Jun 7, 2025 at 10:00 AM
    bodhi armor
    Joshua
    East TX
    Fair point... Thanks
  9. Jun 7, 2025 at 10:22 AM
    chasetheCarguy4x4
    chasetheCarguy4x4 Member
    2003 Toyota Tacoma 4WD 3.4L MFI DOHC 6cyl (5VZ-FE)
    Just grab you a bottle of oem specified brake fluid and top it off each time you drive it until you can get it fixed
