Brake fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dylanmanka, Aug 31, 2024.
  1. Aug 31, 2024 at 9:34 AM
    dylanmanka
    dylanmanka [OP] Member
    Dylan
    2007 Silver Tacoma TRD Off-Road
    Brush guard, trd pro grill, KC lights, cold air intake, softopper, vision wheels
    Noticed that my brake fluid has been need to be filled up more recently. The reservoir was low in late June and noticed again today that it was low, this also causes for the parking break light to come on. I went ahead and topped it off but was wondering if this is normal to add more brake fluid. I got new rear brakes last October and the front are still in good condition, could there possibly be a leak or anyone else experience this?
  2. Aug 31, 2024 at 9:44 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    It's a closed hydraulic system so if you are losing it, there is a leak.
    Clearwater Bill likes this.
  3. Aug 31, 2024 at 9:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    level drops (slightly) as pads wear, fluid compensating for the loss of dimension on the pads
    Level drops if there's a leak.
    Brakes are important. Get it checked out before you suddenly have none.
    PS, Assuming here the statement having new rear brakes only means new shoes and cleaned up drums. Could easily be a leaking wheel cylinder. Or several other possible leak locations.
    Knudsen likes this.
  4. Aug 31, 2024 at 10:06 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you see ne external leaks pull the vacuum check valve off the brake booster and look inside to see if it's full of brake fluid, if it is you will need a new master cylinder and booster.
    1schoir and Clearwater Bill like this.
