Brake grease question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KonaCoffee, Jun 20, 2024.
  1. Jun 20, 2024 at 11:32 AM
    KonaCoffee
    KonaCoffee [OP] Well-Known Member
    Massachusetts
    2019 SR5 Ext Cab, 4WD, Auto, 3.5, 80k
    I watched the video in the maintenance forum for new front brakes. I am wondering what the best “grease” would be for the back of the pads? Also I don’t think he lubed the pins? Should I lube the pins?
    TIA
  2. Jun 20, 2024 at 11:34 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
  3. Jun 20, 2024 at 12:42 PM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Yes, always lube the pins that calipers slide on. Wipe the old grease off, add new grease
    I have used both Sylglide and Permatex Ceramic brake grease, both work well.
    SH10151 likes this.
  4. Jun 20, 2024 at 12:48 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    For our trucks specifically I like to sparingly lube the pins. Every tire rotation it's a good idea to try sliding the pins back and forth just to keep them from siezing. The pad backings and contact points where it's metal on metal, (I) use Moly grease
    for conventional setups with a rubber dust boot involved, use silicone lube or a dedicated brake grease on the slide pins and moly grease on the pad contact points including the pack and between the shims
    Big tall dave likes this.
  5. Jun 20, 2024 at 1:00 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Last time I did my brakes I wire wheeled and lubed my pins because they were all pitted and uneven from rust. Since then I’ve been thinking I should replace the pins with some modified stainless steel bolts (cut off the threads and drill a hole for a lynch or mini hairpin?)
    Anyone in the rust belt tried this or happen to know the pin size and length of the stock pins so I can buy some bolts before pulling a wheel?
  6. Jun 20, 2024 at 1:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I don't lube the pins, it just attracts dirt and washes off anyway. They don't do it at the factory and factory brakes don't make noise until they're metal to metal. It's more important to just keep them clean
    The only pins that should be greased are the ones on floating calipers (piston on one side only) where there is a rubber boot protecting the pin and keeping the grease in
    JFriday1 and usmc2msu like this.
  7. Jun 20, 2024 at 1:26 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    No lube on the pins whatsoever. All it will do is attract dirt and debris and accelerate where and sticking. These things are super cheap fellas. You can buy a hardware kit for like $2.50
    wilcam47, usmc2msu and Steves104x4 like this.
  8. Jun 20, 2024 at 1:32 PM
    Barsoom
    NW GA OTP
    I thought that was the pins we were talking about? Caliper sliding pins? No?
  9. Jun 20, 2024 at 1:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Technically the pins on our 6-lug calipers are pad retainers. They just keep the pads in place. There's supposed to be some room for wiggle and movement. Hence the clack-clack of the pads shifting when you go from reverse to drive
    The term slide pin usually refers to a floating caliper where the piston(s) are only on one side and the whole caliper has to squeeze down and release. Those sliders need grease and it has to be protected under a rubber boot to do it's job. They really shouldn't be moving up and down, just sliding in and out
    Tomato/tomahto I know.. but we're just talking shop here
  10. Jun 20, 2024 at 2:04 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    No, the discussion was the pad retaining pins.
    These calipers are not floating, they are four piston, the calipers are bolted in place.
    Barsoom[QUOTED] likes this.
  11. Jun 20, 2024 at 2:50 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Kona Coffee is really good
    Kolache007, TacoManOne and Barsoom like this.
  12. Jun 20, 2024 at 2:55 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    This is an absolutely horrible idea. Get replacement pins.
  13. Jun 20, 2024 at 2:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It is
    You could be driving around in the middle of nowhere in Hawaii, go into a shitty run-down gas station with dirt floors and they'll have a minimum of 3 types of kona coffee ready to go. Chocolate, macadamia nut, etc
    Delicious
  14. Jun 20, 2024 at 3:39 PM
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    My wife and I brought a couple of bags of beans back from a coffee farm called Hala tree last summer, some of my favorite.
  15. Jun 20, 2024 at 3:50 PM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    Haven't a clue if such a thing exists for the Tacoma, but I replaced my factory caliper pins on a Triumph motorcycle with titanium ones. I do a fair bit of off pavement travel and the caliper pins were constantly getting gummed up with shit. I used to pull and polish them after longer trips, but since putting the titanium in they've been far less corroded.
  16. Jun 20, 2024 at 4:22 PM
    KonaCoffee
    Massachusetts
    Haha, the name Kona Coffee is the name of the color of my 2014 CR-V. I’ve never had any Kona coffee, but I’m definitely gonna go out and try some now!
    Phlogiston and b_r_o[QUOTED] like this.
  17. Jun 20, 2024 at 4:23 PM
    KonaCoffee
    Massachusetts
    Thanks for all the great suggestions for lubing the pads and treating the pins, etc., FYi: I got all new hardware which included pins! I am not going to lube the pins. The video is really good and the guy seems to know what he’s doing. I just didn’t notice him addressing what he did with the pins but thank you for all your help.
    Barsoom likes this.
  18. Jun 21, 2024 at 4:15 PM
    Big tall dave
    I’m talking about the two, non-graded, steel pins that hold the brake pads on each caliper.
    Up here they rust quickly and I’d bet my pads are hanging-up on the rust/pitting and wearing them unevenly.
    I’m not opposed to replacing them with OEM but I thought stainless steel would be a more permanent and smarter solution. Why would replacement stainless bolts be an absolutely horrible idea?
    joba27n and Phlogiston like this.
  19. Jun 21, 2024 at 5:37 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    While I don’t think this is a terrible idea, it would be a waste of my time due to the inexpensive nature of these pins. However, it would be a good experiment and I’m all for experimenting. Note that stainless steel is not as strong as regular steel, but in this application I do not think strength is a concern.
    Measured like a screw, from under the head to the pin hole is 3.515, with a diameter of 0.247. The mushroom head is 0.313” in diameter. Total length of pin from under head is 3.717”.
    Good luck finding a very long partially threaded bolts long enough; perhaps McMaster Carr?
    Edit: add link to McMaster Carr pins:
    McMaster-Carr
    Big tall dave[QUOTED] likes this.
  20. Jun 21, 2024 at 5:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I use Permatex silicone ceramic, but pretty much any high-temperature grease will do. Pins should be lubed to prevent rust buildup.
