Brake "groan" when slowing after a bumpy section?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rustyota, Jul 27, 2010.
  1. Jul 27, 2010 at 10:33 PM
    Rustyota
    Rustyota [OP] well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Hey all. I tried to search this, but I don't really even know what to enter to search. I have this wierd sound that happens when braking after a bumpy section while going relatively slow (like 10-20 mph) mostly off road, and I'd really like to know what it is. It's like a mechanical groaning sound that seems to be coming from the engine compartment. It's hard to describe, so forgive me... It sounds almost like a mini air compressor that runs for 1-2 seconds. I get no ABS light or anything, and no noticable difference in feel. Anybody have any knowledge of this or hear something similar?
  2. Jul 27, 2010 at 10:40 PM
    DevL
    DevL Well-Known Member
    I get three noises offroading. Brakes up front groan. Drums groan pretty bad. Then there is TRAC kicking in... which does not set off the skid control warning.
  3. Jul 27, 2010 at 10:45 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    I'm 99.3% sure it's not coming from the brakes themselves--definitely coming more from the center of the vehicle in the front. What is the TRAC?
  4. Jul 27, 2010 at 10:53 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    on my prerunner, if im braking and i got over a random bump a lil hard it groans up front and the brakes loosen up...toyota says nothings wrong but its happened with my friends in the car and they've heard the noise n have see me pump the brakes around twice to come to a stop...
  5. Jul 27, 2010 at 10:57 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Sounds similar, but I've never felt the brakes loosen--just hear the groan. I wonder if it's an ABS component that just makes that noise?? Did toyota explain what it was, or just say it's nothing wrong? (so helpful they are sometimes...)
  6. Jul 27, 2010 at 11:02 PM
    myname150
    myname150 Well-Known Member
    Lol i get this all the time. it usually happens if im comming to a stop sign where theres a puddle and i brake too hard, so the ABS kicks in.
    And ive heard it happen when i was braking to a stop and my front passenger side tire hits a patch of mud.
    My guess its just normal ABS operations.
  7. Jul 27, 2010 at 11:02 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    "we have inspected ur vehicle and everything is perfectly normal"...thats what i got 3 times i went in before 36,000...so...no help what so ever...damn dealership.:mad:..sorry bud.
    i got nothin
  8. Jul 27, 2010 at 11:04 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Gotta love the stealership.... Thanks for the info!
  9. Jul 27, 2010 at 11:06 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    no problem...n thats after i rear ended some chick who thought i was crazy that i couldnt brake...no damage tho. but my friends believe me after it happeing to them
  10. Jul 27, 2010 at 11:43 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds like normal abs operation to me. Slam on the brakes in loose dirt. Without abs, your wheels lock and you slide. Since you have abs, that system will kick in. Whatever noises you are hearing as you come to a controlled stop are normal.
  11. Jul 28, 2010 at 8:24 AM
    Finsterino
    Finsterino Active Member
    Florida
    07 TRD
    Yeah, mine does it also (makes noise and brakes are very soft) going over large bumps in the road - scary when the brakes don't work!!
    I imagine the noise is the ABS system under the hood as it "pumps" the brakes for you.
    I think the ABS engages itself because it thinks some wheels are skidding, as it goes over the bumps.
  12. Jul 28, 2010 at 8:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    My Tundy acted the same way. I recently switched to ceramic pads (Wagners) and it went away.
  13. Jul 28, 2010 at 8:54 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    ya i figured it was the abs (after a lil while later) so i dont really pay much attention to that unless it happens
  14. Jul 28, 2010 at 10:06 PM
    myname150
    My guess is this is whats activating. because to me it always sounds like its coming fron the passenger side under the hood. Sorry for the crappy quality, i took this with my iphone
  15. Jul 29, 2010 at 11:57 AM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    You all rock--I feel a lot better knowing that this isn't just my truck and that you all think it's the ABS. That was my suspicion too. I'm going to have to pay attention to the brake pedal next time to see if it seems to go soft (huh huh) when that happens.
    Thanks again all!!!
  16. Jul 29, 2010 at 5:23 PM
    myname150
    No Problem ;)
