Brake help please.
Discussion in 'Technical Chat' started by Steel Mill, May 14, 2023.
  1. May 14, 2023 at 4:50 AM
    Steel Mill
    Steel Mill [OP] Well-Known Member
    Greg
    2007 Toyota Tacoma
    I have a 2007 Tacoma 4x4. Here’s my problem. When I hit my brake pedal it goes about halfway down or more then if you let off and hit the pedal again I have a firm brake like you should have. ABS and Brake light are on. Then it will turn itself off then back on. I’ve been hearing the ABS motor kicking in and out under the hood. So out of the graps and giggles I pulled the ABS 2 fuse yesterday. I’ve got a great brake pedal now. Does that mean that the ABS motor is bad or is my problem else where ?
    Thank you for the help and I’m sorry if this is in the wrong place.
    Edit :
    That did not solve my problem. My brake pedal is right back to the same thing.
  2. May 14, 2023 at 6:00 PM
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Never mind. I lost my good firm pedal again.
  3. May 14, 2023 at 11:19 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Check your wheel bearings.
    muddog321 likes this.
  4. May 15, 2023 at 12:02 AM
    allwaysbroken5
    allwaysbroken5 Well-Known Member
    jerry
    2010 Tacoma 2.7 manual
    none
    you may have air in the abs you need a computer to bleed the abs
  5. May 15, 2023 at 12:32 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    ABS codes should be read! Note most auto store readers do NOT read ABS so call and ask first or buy one about $100 or ask on TW for someone near you to borrow or read codes.
    How many miles on the 07 and what else done to front/rear brakes, suspension, etc.
    ABS could be bad wheel bearing as above so the ABS ring is full of crap, bad ABS sensor, damaged ABS wire, etc.
    Could be issues in rear as each side also has an ABS sensor.
    After you resolve ABS lights then if still pedal issues bled all brakes, look for calipers sticking, and ask again on brakes as many possibilities front and rear.
    Chuy likes this.
  6. May 15, 2023 at 5:23 AM
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Never would have thought that. The two doesn’t even have anything to do with each other really. I could be wrong though. Wouldn’t be the first time. I definitely check it out. Thanks for the info.
  7. May 15, 2023 at 5:24 AM
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Thank you for the info. Honestly haven’t changed anything to get air in the system but I will have it checked.
  8. May 15, 2023 at 5:28 AM
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Thank you for the info. My 07 has 161,000 on it. I did notice it pulling to one side a couple weeks ago then it stopped pulling. I know it doesn’t fix itself but it quit. I will either buy a scanner or have someone do it for me. Thanks
  9. May 16, 2023 at 11:33 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  10. May 16, 2023 at 2:48 PM
    Steel Mill
    Greg
    2007 Toyota Tacoma
  11. May 16, 2023 at 6:46 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    As they degrade they can contaminate the sensors, also can reduce initial pad clamp due to wheel wobbling and spreading out the caliper pistons.
  12. May 16, 2023 at 9:53 PM
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Wow. I didn’t honestly know that. I definitely appreciate the info. I will definitely check it out.
    Here’s a example of what I’m dealing with. I drove home from work this evening and I had a soft pedal. It set for probably 15 minutes till I left again. Had a great firm pedal all the way to my destination which probably 45 minutes drive. It set there for probably 2 hours. Then back home and it had a soft pedal again. I am pure lost at the cause.
