brake help .....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Death_Stalker, Dec 18, 2009.
  1. Dec 18, 2009 at 9:41 AM
    Death_Stalker
    Death_Stalker [OP] " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    i just changed my front brake pads. Everything was done how its suppose to be but now i have a problem. when i test drove the trucks and apply breaks the truck dosent stop . The break pedal is pressed in completely and still no drip from front breaks whatever it is, its from the rear ... What did i do wrong ? how do i fix this ?
  2. Dec 18, 2009 at 9:43 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    its sounds like a bad brake hose or maybe you have it twisted
  3. Dec 18, 2009 at 9:45 AM
    Death_Stalker
    Talha
    Cypress, TX
    it was just fine before the pad change, i dint even touch the brake lines or bent anything ... how do i bleed the brakes ?
  4. Dec 18, 2009 at 9:45 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Is your brake fluid reservoir full?
  5. Dec 18, 2009 at 9:46 AM
    mjp2
    NJ
    Also, do you have brakes if you pump the pedal? It takes a few pumps to seat the new pads after you compress the piston into the caliper to fit the new pads.
  6. Dec 18, 2009 at 9:48 AM
    David Tarantino
    N.J.
    08 tacoma
    you had to remove the caliper to replace the pads
    it is poss that you have the hose twisted
  7. Dec 18, 2009 at 9:51 AM
    Death_Stalker
    Talha
    Cypress, TX
    i changed the rotors too so i took the whole caliper out and replaced the roter ... what do you mean by its twisted ? about how many times should i pump the break padal for it to become normal i sis about 25 times yes my brake resevoir is full
  8. Dec 18, 2009 at 9:54 AM
    David Tarantino
    N.J.
    08 tacoma
    ok just so i understand what you are saying
    are the brakes going to the floor
    if pump them do you get brakes
  9. Dec 18, 2009 at 9:56 AM
    mjp2
    NJ
    Pictures will definitely help. Post them of the front flexible lines going to the calipers on both side of the truck.
    If your wheels are off, also take and post pictures looking at the brake pads from the top of the calipers.
  10. Dec 18, 2009 at 10:08 AM
    Death_Stalker
    Talha
    Cypress, TX
    yes the brake pedal is going all the way to the floor and the brakes are not applying .... truck does not stop
  11. Dec 18, 2009 at 10:09 AM
    ptsimpso
    ptsimpso Member
    NC
    2010 4x4 TRD-Sport
    Stereo
    If you also did the rear drums, and didn't properly set the star adjuster, you might have this symptom. When you apply the brake pedal all of the fluid in the brake system will go the path of least resistance, if your rear shoes aren't making contact with the drum the fluid will go back there, and you will never get front brakes to engage.
    Turn the car off, and apply the parking break, if you feel no/little resistance then this is your problem. To fix, you can either remove your rear drums and re-adjust, or you can pump the parking brake again and again, you will hear the rear brakes make a ratcheting noise, do this as many times as it takes till your parking break feels "right" again.
  12. Dec 18, 2009 at 10:13 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If you didn't remove your brake lines, you shouldn't HAVE to bleed the system. Since you spread your pistons apart however to get the new pads in there, it will take a few pumps to get the pads seated back on the rotor. You stated however that you have pumped the pedal 25 times or so, and that should be more than plenty. If you still have no pedal pressure:
    1. Check the system for a leak. The front brake lines on my '05 aren't rubber but metal, so when I do any brake work I don't move the caliper any further than necessary and hang them via a piece of twine from the coil springs. Is it possible you moved the caliper too far and kinked/split one of the metal lines?
    2. Did you remove the brake line from the caliper at anytime?
    3. Did you remove/loosen the bleeder screw at any time without pressure being applied to the pedal?
    4. Did you disassemble the caliper in anyway or lose one of the pistons and simply push it back in place?
    5. Did you fool with the rear brakes at all?
    6. What do you mean there is no drip from the front brakes, only the rear? Do you have the bleeders open or something? If trying to bleed be sure to constantly check your master cylinder to ensure there is brake fluid present. If you run the MC dry you will have to start all over.
  13. Dec 18, 2009 at 10:15 AM
    David Tarantino
    N.J.
    08 tacoma
    if only did the front start at right front have someone inside the truck
    pump the pedal tell you get one then have him hold the pedal down
    open the bleeder on the caliper do this tell you have all the air out
    then do the same on the left front
    if you did all the brakes start at the r/r then l/r then l/f r/f
    and ck the master for brake fluid
  14. Dec 18, 2009 at 10:18 AM
    Death_Stalker
    Talha
    Cypress, TX
    did not touch the rear drum at all
  15. Dec 18, 2009 at 10:21 AM
    Death_Stalker
    Talha
    Cypress, TX
    1 & 2. i did unscrew the metal breaklines but dint bend or move them at all ... there is no crack or leak on them . i unscrewed them both again and break oil is flowing through it properly as it should.
    3. Only removed the rubber cap but did not loosen the bleed valve ( golden color with a hole on it ) at all
    4. Calipers are fine the way they are suppose to i have changed brakes on many cars before never came across a situation like this ....
    5. Dint touch the rear brakes at all
  16. Dec 18, 2009 at 10:23 AM
    Death_Stalker
    Talha
    Cypress, TX
    ok does the truck needs to be on idle ?
  17. Dec 18, 2009 at 10:25 AM
    mjp2
    NJ
    Ding! You have air in your brake lines. Bleed your brakes.
  18. Dec 18, 2009 at 10:26 AM
    David Tarantino
    N.J.
    08 tacoma
    if you are working br your self open the bleeder so brake fluid can flow
    keep an eye on the master so run out of fluid when you get a even flow
    close the bleeder and do the same on the l/f
  19. Dec 18, 2009 at 10:27 AM
    David Tarantino
    N.J.
    08 tacoma
    no
  20. Dec 18, 2009 at 10:28 AM
    Fortech
    CANADA
    You removed your brake lines and introduced air into the system, now you have to bleed. You probably didn't run into this on past vehicles because you didn't remove the lines. No matter the make/model, remove lines = bleed.
    Might as well head to the parts store and pick up some fluid and a "one man bleeder" or equivalent. It allows you to bleed the brakes by yourself, but isn't necessary. I bought one this spring for around $10 and have used it several times on the Taco and motorbikes - love it.
