Brake help
Discussion in '1st Gen. Tacomas (1995-2004)' started by DieselDog409, Oct 30, 2023.
  1. Oct 30, 2023 at 6:28 AM
    DieselDog409
    DieselDog409 [OP] Well-Known Member
    Paul
    Frameless 2000 tacoma V6 5spd e locker rotbox.
    Frame delete cylinder 5 delete glasspack
    I am broke as hell right now and my tacoma's front 6 lug rotors are cracked bad and i wonder if the used 04 tundra rotors i have will work on it for a while.
    It will be fixed right at some point but right now i have 2 other trucks to fix before i get to this one.
    This is my parts getter truck.
    Thanks
  2. Oct 30, 2023 at 6:41 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  3. Oct 30, 2023 at 7:14 AM
    jakeadake
    jakeadake Member
    Yeah you have to use the tundra calipers though for those tundra rotors. I believe either 13wm or 13we are stamped into he calipers depending on size and use either a 219mm or 231mm rotor. Just measure the rotors you have off the tundra and match them up to the correct calipers they can't be mismatched
  4. Oct 30, 2023 at 8:01 AM
    DieselDog409
    Paul
    Dang i dont have calipers for it as the rotors were off a customers truck that i did brakes on a while back.
    Whelp back to the drawing board...
