Brake Imbalances. What kind of trouble am I looking at?
Discussion in '1st Gen. Tacomas (1995-2004)' started by N81292, Oct 6, 2016.
  1. Oct 6, 2016 at 1:56 AM
    N81292
    N81292 [OP] Well-Known Member
    EDIT- UPDATE: Turns out I am getting totally new brakes at the rear
    Now, I am left wondering with one more thing...
    My front brakes imbalance is at 22%. As I mentioned earlier, the maximum % allowed to pass inspection is 25%. So I am wondering how easily/quickly brakes can become imbalanced.
    I plan on selling this vehicle within 5 months, so I probably should get the front done too, whether that means getting totally new brakes up front or just having them adjusted.
    Had my 2001 Prerunner inspected today, and was told that my rear brakes were imbalanced by 99%! I have a copy of the graph he showed me.
    The maximum allowed to pass inspection is 25%, and my front brakes are at 22%.
    I took it to my mechanic today and he needs to look at it to troubleshoot. I don't even know if the truck has disc or drum brakes. So anyway, my question is how much should I expect this to set me back?
  2. Oct 6, 2016 at 6:41 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    It sounds like one side of your rear is doing all the braking. does the truck pull to one side when you stop/slow down?
    The other figure you quoted is probably how much you've got left on your brake pads. The front brake pads (and rotors if you need them) are easy to replace if you've got a basic wrench set and some time. The rear...you'll have to figure out why one side is grabbing and the other isn't. You have drums in the back.
    Too many what-ifs to give you a decent price assessment right now, sorry.
  3. Oct 6, 2016 at 7:01 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Drum Brakes on the Rear. Not sure where you are located, but if there isn't a rust issue, they probably just need adjusting. I have found that keeping the rear drums adjusted makes a big difference in braking.
    Mush Mouse and TooMuchToDo like this.
  4. Oct 6, 2016 at 10:56 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Using the parking brake on a regular basis
    keeps the rear brakes adjusted automatically.
    If ya don't engage the parking brake often enough
    then the rear brake engagement will go out of alignment.
    And the pads will wear unevenly or incorrectly,
    thus causing uneven brake pad - drum wear.
    If the brake auto-adjust mechinism(s) is rusted or frozen in place
    then obviously the auto-adjust brake syst. will not work as it should.
    And the brakes will wear unevenly
    Any rust or corrosion will need be cleaned up
    /or components will need replacing so that it can function as it should.
    Uneven brake wear that goes long without attention
    will likely need a full repair using fresh components.
    Brakes are a critical element of any vehicle
    and their maintenance or repair should not be ignored.
    Obviously the state inspection is meant for those
    whom disregard their vehicle maintenance.
    And need a reminder to do so.
  5. Oct 6, 2016 at 3:46 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Is this a California thing for new vehicles that can be read via the OBDII and a scanner ??
    I just can picture some people I know installing brake pressure gauges on all 4 wheels
    You would drop your truck Monday morning and if your lucky pick it up Friday and go home without brakes
  6. Oct 6, 2016 at 8:50 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    California does not do "state run" vehicle safety inspections.
    But don't worry... this state will shaft you for driving, by other means.
  7. Oct 6, 2016 at 11:21 PM
    N81292
    I drive an automatic, so no parking brake.
    This sounds about right to me. I might just opt to get entirely new brakes all around if the cost is bearable.
  8. Oct 6, 2016 at 11:54 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Huh I have an automatic and I always use the parking brake. It saves your transmission. I always put it in neutral then pull the parking brake then put the transmission in park.
  9. Oct 7, 2016 at 2:47 AM
    N81292
    Wait...what year is yours? I got a 2001 prerunner. All I have is the emergency brake
    Edit: ok I'm stupid. Didn't know those were the same thing. I've never used it so I'll do that from now on whenever I park :) I know that especially helps when you're parking on hills. Hmm
  10. Oct 7, 2016 at 4:53 AM
    DestroyerLite
    DestroyerLite Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    X2, I do the same thing. Little push and pull of a lever is good enough insurance for me.
    --Dan
  11. Oct 7, 2016 at 11:36 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Sounds about right. Put 1K# in the bed and the back brakes will work.
  12. Oct 8, 2016 at 6:55 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah i bet with you having never used your parking brake has caused most of your issues there since it has never been able to self adjust themselves...
  13. Oct 11, 2016 at 9:32 AM
    N81292
    Well it turns out I am getting new rear brakes.
    I know the rear has drum brakes, but what about the front?
  14. Oct 11, 2016 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    disc in the front
  15. Oct 11, 2016 at 9:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    There is no adjustment available to the front.
    You don't say anything about mileage or condition. It's unusual to need rear brakes before 100k or so. But shoes and a hardware kit should be inexpensive, material wise.
    If the front rotors are not excessively scored, and the pads are adequate thickness, evenly worn, ask the mechanic to pull the caliper mounting bolts, clean, lubricate and replace. This may free them up to work a bit more evenly.
  16. Oct 11, 2016 at 9:54 AM
    N81292
    Well, she's just about to hit 155K miles, which is considerably low for a 2001 model. But I am the 3rd owner now so I only have a brief knowledge of its history. My mechanic's estimate was under $500.
    But what do you mean there's no adjustment for the front? Is that because they're disc brakes as opposed to drum? sorry I am clueless to the difference.
  17. Oct 11, 2016 at 9:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    For just the rears? :eek:
    Even with all new parts (which should make labor less) that's a lot-'o-bucks.
    I mean I know we don't know what's wrong exactly, but still.............
    Correct.
    They can be 'serviced', but not adjusted.
    98tacoma27 likes this.
  18. Oct 11, 2016 at 9:59 AM
    N81292
    Hmm.. well I'm going to get it inspected again once the labor is done. Wonder how quickly that 22% imbalance will increase.
    but if the rear was imbalanced at 99%....yikes. I wonder how much I was unnecessarily taxing my front brakes when stopping. It must have been killing them.
  19. Oct 11, 2016 at 10:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    Imbalanced is a side to side thing on one axle. Your 99% only means one rear brake was not working.
    22% in the front means one is working better than the other. 'Why' is the question. Again, highly possible that a simple inspection and servicing of the mounting pins could correct this.
  20. Oct 11, 2016 at 10:03 AM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Interested to know where they have state inspections for brakes?
