Brake Imbalances. What kind of trouble am I looking at?
Discussion in '1st Gen. Tacomas (1995-2004)' started by N81292, Oct 6, 2016.
  1. Oct 11, 2016 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    PA has a state safety inspection. The emissions inspection is a joke and only required in certain areas (it's based on per capita).
    Inspected under the Safety inspection are:
    • Brakes
    • Tires
    • Windsheild wipers
    • All exterior lights and signals
    • Body (no rust holes)
    • Chasis (no rust holes)
    • Exhaust and emissions must be intact
    Here's the entire program
    http://www.dot.state.pa.us/Public/D...als/Pub_45 Inspections Regulations/PUB-45.pdf
  2. Oct 11, 2016 at 10:12 AM
    N81292
    N81292 [OP] Well-Known Member
    hmmm. Doesn't seem as drastic or urgent as the rear thankfully.
    I'm actually stationed in Germany, and while I'm not sure if we're going by German regulations here, all vehicles need to go through this inspection in order to be registered/sold.
  3. Oct 11, 2016 at 11:42 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    So this work is being performed in Germany?
  4. Oct 11, 2016 at 11:43 AM
    N81292
    Yes
    On military base
  5. Oct 11, 2016 at 12:34 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Should have some facility their where you can do your own maintenance, being a military base (thank you for your service). Every (nearly) base I was stationed at had an MWR related facility where we could work on our cars. And if you weren't completely knowledgeable, there was always someone around who could advise. Brakes aren't all that complicated (well, the rears can be). Front disc pads can be replaced with nothing more than removing the front tires.
    The rears are drum style and while more complicated, use ancient technology. Best advice, tear only one side apart so you can refer to the assembled side while putting it together...
  6. Oct 11, 2016 at 10:21 PM
    N81292
    That is correct. We do have an open space with self help bays and I'm not sure what equipment is available. I think I'm going to give it a look when I replace my brake fluid and bleed the brakes if I am feeling brave one day lol
