brake isssues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 76FJ, Nov 17, 2015.
  1. Nov 17, 2015 at 9:12 AM
    76FJ
    76FJ [OP] Member
    I've tried searching the site but I can't find exactly what I'm looking for. So hopefully someone could help. I have a 2010 DC 4x4 6 cylinder Tacoma that I just changed the front pads and rotors on. At times while braking I need to pump the pedal a couple of times in order for the brakes to work. No all the time. It almost seems like there is air in the brake lines but the bleeder valve was not opened during the installation. I've replaced the pads before and never really had any issue. What do you guys think?
  2. Nov 17, 2015 at 9:20 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    X2. Always bleed the lines when does ng brakes. And change/flush fluid every 2 years for optimal performance.
    moondeath likes this.
  3. Nov 17, 2015 at 9:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah bleed the system.
    Also when changing pads. NEVER push the fluid from the calipers back into the system. Depress the brake pedal and lock it in place (via a brick, zip tie, another person.) This makes it to where fluid cant be pushed back up the line. Crack the bleeder screw, and then push the old pad in to push out all the nasty crap in the caliper out. Replace pads, put caliper back on. then pump the pedal to get brakes back before moving.
    balljoint and moondeath like this.
  4. Nov 17, 2015 at 9:23 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    ^^^ This exactly. This is one of the biggest things people forget about. Not flushing the fluid will eventually lead to caliper failure from corrosion and the breakIng ability will decrease greatly.
  5. Nov 17, 2015 at 9:28 AM
    76FJ
    76FJ [OP] Member
    Thanks for quick reply. That make sense, I have never flushed the system, how about the rear brakes, would you think they need to be adjusted to accommodate the new pads and rotors?
  6. Nov 17, 2015 at 9:32 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Be careful not to let the reservoir go dry while you're flushing the system.
  7. Nov 17, 2015 at 9:34 AM
    76FJ
    76FJ [OP] Member
    Please forgive my ignorance, but are we bleeding the front 2 brakes or flushing the system and removing the all the fluid and replacing?
  8. Nov 17, 2015 at 9:36 AM
    moondeath
    Pa, Gardners
    You'll want to flush the entire system. Replacing all the old fluid is the goal.
  9. Nov 17, 2015 at 9:42 AM
    moondeath
    Pa, Gardners
    As a side note, once the system is bled and you're confident there is no air in the line, if you still experience squishy brakes there is another problem. Master cylinder worn out, caliper pistons leaking, things of that nature.
  10. Nov 17, 2015 at 2:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  11. Dec 4, 2015 at 1:24 AM
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    TTT for so many TW members complaining about brakes and never heard of flushing your brake fluid on a regular basis.
