Brake Issue after replacing spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SteanAZ, Apr 25, 2018.
  1. Apr 25, 2018 at 7:30 PM
    SteanAZ
    SteanAZ [OP] 2005 dbl Cab, 5ft - SR5 4x4
    Phoenix, AZ
    2005 Tacoma SR5
    STOCK
    I have always changed my spark plugs and never had any issues. I just finished changing the spark plugs for the first time on my 05 Tacoma, 4l - v6. After changing them, the engine runs fine but there a small whistle sound on the driver side of the engine and my brakes are very stiff to the point of almost having no brakes. HELP! Anyone ever experienced this. I'm just starting my Google research but figured TW is a great place to begin.
  2. Apr 25, 2018 at 7:31 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    vacuum hose to the brake booster...
  3. Apr 25, 2018 at 7:36 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    This OP, make sure the hose is still connected and or the one way valve is not damaged.
    Tyler Lacasse and SteanAZ[OP] like this.
  4. Apr 25, 2018 at 7:47 PM
    SteanAZ
    Phoenix, AZ
    2005 Tacoma SR5
    STOCK
    Alright i'll go double check everything. Thanks for the quick replies buds
  5. Apr 26, 2018 at 3:04 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Let us know what you find.......
  6. Apr 26, 2018 at 7:03 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Probably split the hose or a crack (whistling noise)...
    Jeffs68 likes this.
  7. Apr 26, 2018 at 11:26 PM
    SteanAZ
    Phoenix, AZ
    2005 Tacoma SR5
    STOCK
    Thanks for the replies. Ended up not securing the vacuum hose from the brake booster like mentioned first, it was loose on the intake valve it connects too. And it was just barely loose, which goes to show the impact it has. I double checked all other hoses, clamps and what not. Started the engine, brakes became a bit soft and normal functioning after a few revvs. Its sounding great and running perfect for 103k miles.
    kimo likes this.
  8. Apr 27, 2018 at 12:19 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    SteanAZ[QUOTED][OP] likes this.
