Brake issue. Good pedal but no srtopping.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ihave2tacos, Aug 3, 2018.
  1. Aug 5, 2018 at 9:50 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Did you try the standard booster test? Pump the brake pedal with the engine off, then keep pressure on the pedal while you start the engine. The pedal should then go down as vacuum from the engine reaches booster.
    cruxofthebisquit likes this.
  2. Aug 6, 2018 at 11:10 AM
    Ihave2tacos
    Ihave2tacos [OP] Member
    95 Tacoma 4WD
    Yes sir and I got no travel at all. I just picked up the booster (Bumper to Bumper is the only one with a warehouse in town and they aren't open on weekends so just now getting one).
  3. Aug 6, 2018 at 1:58 PM
    Ihave2tacos
    95 Tacoma 4WD
    And the winner is: Brake Booster.
    I've never seen one behave this way. I've always been able to overpower a failed/weak booster while still knowing it was the problem. But I've never had one fail in a Toyota before, so there's that.
    Thank you everyone for your time and trouble. I really appreciate the feed-back. Thank you again!
  4. Aug 6, 2018 at 7:13 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    What about weak brakes that can’t hold the truck still at a stop light? Especially with my AC on I almost have to stand on the pedal to keep it from rolling or lurching foreword when the ac comes on. Someone told me torque converter may be an issue once but figured you guys here may know
  5. Aug 7, 2018 at 5:30 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Brake booster.
  6. Aug 7, 2018 at 8:44 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Ok I’ll look into testing it but I beleive I did years ago and couldn’t find a failure. Maybe I’ll just replace it.
  7. Aug 7, 2018 at 9:17 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I posted a link earlier in this thread that has 3 different tests that don't require special equipment. Go through those before spending the money. Could be as simple as a vacuum leak.
    1997tacomav6 likes this.
  8. Oct 25, 2019 at 12:28 AM
    808toyotaco
    808toyotaco Member
    2000 black tacoma trd
    none
    thanks for the information
