brake issues help?
Discussion in '4 Cylinder' started by ccc, Nov 17, 2009.
  1. Nov 17, 2009 at 8:40 AM
    ccc
    ccc [OP] New Member
    every once in a while when i'm breaking right before i come to a stop, the breaks start bucking/locking up a little bit. anyone have any ideas?
    its a 2004 regular cab 4x4, i just purchased a little over a month ago.
    thanks in advance
  2. Nov 17, 2009 at 9:32 AM
    alteredillusions
    alteredillusions Well-Known Member
    Wichita KS
    SR5 2.7 manual
    Is it bucking and locking or polsating?
  3. Nov 17, 2009 at 10:16 AM
    ccc
    ccc [OP] New Member
    once they lock up i let off (but its when i need to be breaking so...) i'll press on and its just a bit jerky almost like the caliper catching on something causing it to pulse break. does that help describe it better?
  4. Nov 17, 2009 at 10:26 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Is there a grinding sound?
  5. Nov 17, 2009 at 10:37 AM
    ccc
    ccc [OP] New Member
    no grinding, no noises.
  6. Nov 17, 2009 at 10:50 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Sounds like warped rotors. Anytime you buy a used vehicle you should go replace the brakes, belt, oil and filter, transmission fluid, differential fluid, and most times tires as needed.
    Replace your brakes and rotors and bleed the brakes and you should be fine.
  7. Nov 17, 2009 at 12:02 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Does your steering wheel shudder?
  8. Nov 17, 2009 at 4:14 PM
    alteredillusions
    Wichita KS
    SR5 2.7 manual
    x2 It could be a hung caliper but must of them time you would feel the truck pulling when you aren't braking cause it never released. but then if it is just when you are braking hard you could be feeling the abs working.
