brake issues (I think)
Discussion in 'Technical Chat' started by dmac, May 18, 2008.
  1. May 18, 2008 at 3:31 PM
    dmac
    dmac [OP] New Member
    Buffalo,ny
    02 tacoma trd
    hello,I'm a new member and what a great site. I'm new to toyota. Wanted this truck for a while. Brought it up from Arizona. I have had domestics all my life. Only issue I have is the rocking back and forth when I touch the brakes. If I stop and release the pedal just a little and then hit it, the truck rocks forward. Same in reverse. I had the front shocks replaced due to a leak on the drivers side, and the rear springs seem a little flat for an 2002.Other than the typical complaints ie. dash rattles and clock location, the truck is great.Thanks for the help
  2. May 18, 2008 at 3:36 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Welcome dmac! Get some pics here so we can see that cool truck!:)
  3. May 18, 2008 at 4:00 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    the brakes stop the wheels/tires/hubs. So in theory if there is some driveline slop or play it will rock a tiny bit if you massage the brakes. sounds normal to me.
  4. May 18, 2008 at 4:28 PM
    dmac
    Buffalo,ny
    02 tacoma trd
    Thanks for the reply ellsworth but the more I explore the site I believe the problem may lie in the rear springs. If I touch the brakes the truck rocks more than I believe it should. I have had trucks for 35 years and I've never rocked like this before. I thought maybe the rear braked we not engaging but that has been eliminated. I guess if the springs are weak it may cause the rocking motion.
  5. May 18, 2008 at 5:24 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I have a 2001 and I replac
    ed all the shocks AND the rear leafs cause I felt it getting sloppy at 5 yrs old
  6. May 18, 2008 at 7:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    rear springs sound like they are worn out......get new springs or a helper spring.....should take care of the problem.
