Brake Issues - Intermittent Soft Pedal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Island4x4, Apr 19, 2017.
  1. Apr 19, 2017 at 2:23 PM
    Island4x4
    Island4x4 [OP] Member
    Pat
    96 Tacoma 4x4
    Hey guys,
    New to Tacomas and the Forum. I recently bought an 96 4x4 and have been giving it a good tune up. The brakes had been neglected for awhile and the pedal feel was weird at times and randomly got soft. I replace the rotors, calipers, pads as well as the master. I properly bench bled the master and bled both sides until there were no bubbles and new fluid was coming out.
    The brakes felt really hard and worked great for a few days, now I've been getting intermittent soft pedal issues. They will work great for awhile then go soft and the pedal will be almost at the floor before I stop, pumping helps. Also once they start feeling spongy, if the pedal is applied slowly the brakes are spongy but if I hit them hard the pedal stays up and brakes normally...when i pump up and hold I don't loose any pressure the pedal doesn't sink.
    I'm going to pull apart the back drums in the next couple weeks and see what find, going to replace the cylinders, shoes, and hardware.
    I kind of stumped, I've done a lot of brakes and not had this issue before. Right now I'm thinking possibly something leaking inside the drums but I'm not getting any noticeable fluid loss. The new master was bad out of the box? Or the LPV is bad, it looks like a rusted mess, from what I've read normally a bad LPV causes the rear to lock up.
    Any input would help, Thanks.
  2. Apr 19, 2017 at 2:26 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It could be the LPV bypassing or the master is defective and bypassing.
  3. Apr 19, 2017 at 2:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    Was the master a parts house reman unit?
    When you say you bled both sides, not sure what you mean. But did you start at the wheel furthest from the master, then work your way up to the closest to the master?
  4. Apr 19, 2017 at 2:35 PM
    Island4x4
    Pat
    96 Tacoma 4x4
    Is there a way to Test the LPV? I would like to figure this out without throwing parts at it. Looks like the dealership is the only place to get a LPV and they are expensive..
    Is was a new with reservoir Cardone unit (have not read good things about Cardone)
    I have not bled the the back brakes yet as i will be doing them shortly. I did the passenger then the the driver side on the front.
  5. Apr 19, 2017 at 2:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    I would finish the rear first, and re-bleed everything starting at the rear furtherest from the master.
    Then see what happens.
  6. Apr 19, 2017 at 6:04 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Maybe change out the rear brake cylinders too, they're cheap and easy.
    It's pretty well agreed oem parts are the best to use with these trucks, never once had an issue with a factory Toyota replacement part.
    Usually spongy pedal means it's not bled fully. I recommend using a power bleeder at the reservoir to insure you don't run it dry and a piece of clear tubing into a bottle at the bleeder valve of each corner and pump til there's no bubbles to insure you aren't getting air feeding back in
  7. Apr 19, 2017 at 6:38 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Also consider the brake booster, it can be intermittent with boostage (and a spongy low pedal)
    when starting the 'go south' dance...
  8. Apr 19, 2017 at 11:52 PM
    Laxtoy
    Maltby, WA
    I just reread this. Yeah, you have to bleed all four corners, starting at the furthest corner from the master cylinder, anytime you introduce air to the system. A new master definitely needs to be fully bled.
  9. Apr 20, 2017 at 10:08 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Didn't read all the posts, but since you've replaced all of the basic parts, I'd look into new brake lines from the hard pipe to the wheel cylinder/calipers,,, I don't know if it'll give you the mush feel, but they will cause some problems with "releasing" if the inner wall has collapsed inside; the truck is old and the hose is just as old if it hasn't been replaced.
    When I did mine I bought the rebuild kit from Toyota for the calipers,, cheap and easy,, brakes are rock solid on mine.
  10. Apr 20, 2017 at 10:30 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Sounds like a bad brake booster. About $160.00 If it was just a spongy pedal I'd check brake hoses.
    Since it's going to the floor the diaphragm or seals in the booster are probably bad.
  11. Apr 20, 2017 at 7:12 PM
    Laxtoy
    Maltby, WA
    Again, he didn't fully bleed all 4 corners, just the front brakes. You can't add a new master cylinder and not get air in the system. I don't care how hard you try, disconnecting the brake lines will introduce air into the system.
    The air will find its way to the back where it splits to the rear, that also explains why he had good pedal for a short period of time before the air started to circulate back to the front with the cycling of the brakes.
    Not being properly bled is the most obvious cause of this issue and the cheapest and easiest to try to fix.
    Throwing parts at it is not the best way to fix anything.
    cruiserguy, nzbrock and mechanicjon like this.
  12. Apr 21, 2017 at 5:42 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Yep, completely agree with this. Just think about how you have to connect the master. There is no way you are going to pull the original and then bolt in the replacement instantly, so any air gap that was at the hard lines going into the master will be pushed all the way to each brake.
    The proportion in valve also has a bleeder, but in my experience I never get air out of it if I was bleeding the rears before.
  13. Apr 24, 2017 at 1:05 PM
    cruisedon66
    Pete
    Near St. Louis
    Keep us updated and let us know how it turns out.
  14. Apr 24, 2017 at 1:53 PM
    pulldo
    houston, texas
    Well i finally read all the posts,, my bad,,, yep the guys here are spot on, you have to bleed all 4 wheels, and I agree I usually start at the farthest away from the master cylinder,,, hopefully your new master is a good one.
  15. Apr 26, 2017 at 7:12 AM
    Island4x4
    Pat
    96 Tacoma 4x4
    Thanks for all the input guys, I'm going to do the drums this weekend. I will rebleed everything properly. I've gone over all the brake lines hard and soft and don't see any leaking. I've already replaced the soft lines at the front, I'll check out the back ones again and probably do them as well. Although the LSPV is a rusty mess..hopefully I can bleed it. It makes sense there could definitely be air in the system still, the intermittent thing threw me off. I think when i go up a steep hill it get worse, like air bubbles are moving around? Hopefully that solves the issue.. if not possibly a bad master out of the box or the booster is causing issues. We will see
  16. May 1, 2017 at 12:03 PM
    Island4x4
    Pat
    96 Tacoma 4x4
    Just an update, I replaced the rear cylinders, shoes and hardware. I bled the system and it's stopping better than ever!
    Thanks for the suggestions.
    mechanicjon likes this.
