Brake issues
Discussion in 'New Members' started by TB4doorbrake, May 18, 2019.
  1. May 18, 2019 at 1:26 PM
    TB4doorbrake
    TB4doorbrake [OP] New Member
    2003 4 door tacoma
    My 4 door 2w. Tacoma has 393,000 miles. Never had brake issues until last 5,000 miles. After replacing both front calipers, rotors, pads, rear drums, and shoes twice, I took it back to the mechanic. The truck drives smooth and brakes smooth for a few hundred miles, but gradually gets worse with rear end jumping up and down and now my drums are warped the 3rd time. I saw the discussions and I do not ride brakes or haul loads. I asked mechanic this third time if wheel bearings or LSP and Bypass Valve are the culprit, but he said he had checked this already. I have put all 393,000 miles on myself with no engine trouble. Does anyone have a suggestion of what else has been overlooked? I want to make it to 500k miles with this truck!!
  2. May 18, 2019 at 1:27 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you properly bedding the brakes when the new ones go on? You can only do it so well for the drums, but it should be done. And while the brakes are cooling don’t have the parking brake engaged.
  3. May 18, 2019 at 1:34 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    odd sounding, but maybe your proportioning valve is clogged or brake master cylinder is leaking when applying the brakes. IE its pushing most of the fluid to the rear and thats whats skipping. on normal operation the front takes most of the stopping power, then the rear takes up the rest.
  4. May 18, 2019 at 1:39 PM
    wilcam47
    Will
    Bourbon state
    also, different vehicle but my brake booster had a leak and was constantly pushing the brake, I thought the front was going to shake itself to pieces. Then my calipers were smoking hot...
    Taco critter and irayfz6 like this.
  5. May 18, 2019 at 2:00 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  6. May 18, 2019 at 2:03 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    Taco critter likes this.
  7. May 20, 2019 at 5:57 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  8. May 20, 2019 at 8:07 AM
    WillB72
    WillB72 Active Member
    Will
    Ontario, Canada
    Looking To trade my Colorado for a Taco.
    Welcome to TW.
  9. May 20, 2019 at 8:37 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
