Brake light and check engine light on
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotanation29, Jun 16, 2012.
  1. Jun 16, 2012 at 12:21 PM
    yotanation29
    yotanation29 [OP] Well-Known Member
    ADRIEL
    CHULA VISTA
    98 TRD
    all pro upper a arms, icon extended travel 3", bumper cb, clarion nav, and much more to come!!
    I just bought my 98 Tacoma about a month ago, and after I took it for smog test (which it failed :mad:), my check engine light came on and my emergency brake light came on. I have no emergency brake so idk why that light is on, and they said the check engine light was on when it came in, and that the emergency brake light would turn off after a few miles and it hasn't. Should I just take it a Toyota dealership and have them check it out or what?
  2. Jun 16, 2012 at 12:28 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    What do you mean you don't have an emergency brake? Did you remove it completely? For the check engine light, have the code read and try to pinpoint the cause.
  3. Jun 16, 2012 at 12:36 PM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    They said there were two fault codes, and when I bought the truck the guy I bought from said the e brake was disconnected. If there's anyone in the SoCal area that know about this kind of stuff who doesn't mind looking at it for me that'd be awesome
  4. Jun 16, 2012 at 7:33 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    A couple of things:
    1) Go to AutoZone, Advance, O'Reilly's, whatever and have them run the CEL codes. Report back what codes you get.
    2) Check your brake fluid level in the reservoir. It may be low which could throw the "E-Brake" light.
    3) I would advise hooking the E-Brake back up and getting it functional. I wouldn't rely on my truck hanging in gear to keep it from going somewhere unattended or unintended.
    4) Is your truck experiencing any problems (rough idle, poor acceleration, sputtering, etc)?
  5. Jun 16, 2012 at 7:36 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Unplug ur brake master cylinder reservoir sensor. I did and my light went away. Going to replace my brake fluid and see if it helps
  6. Jun 16, 2012 at 7:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The sensor is bad or your fluid level is low.
    Replacing the fluid won't make a difference on a bad sensor.
    If the fluid is low, you likely need to change your pads. That's how disk brakes work. The pads wear, the pistons extend out of the calipers (by about 1/2"!), which pulls fluid from the reservoir.
    In a properly designed system with an owner who doesn't "top off" his brake fluid, the light will come on before the calipers wear enough to damage the rotors.
    When you compress the pistons to install the new pads, the fluid will push back into the master cylinder and the light will go off.
  7. Jun 16, 2012 at 7:49 PM
    goomba
    Josh
    San Antonio Fl
    I have new pads and my shoes are fine, half life. I dont have to add brake fluid, but it is brownish in color, and I think that is causing the sensor to go off. But i dont know, but old brake fluid is bad.
    EDIT: and my reservoir is full
  8. Jun 16, 2012 at 7:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not an option in California.
    There's a reason the guy working at Autozone makes $8/hour and the dealer tech makes $15+
    There were a few lawsuits because parts store techs were reading codes and recommending purchases. Of course, SOMETIMES an O2 code actually means that Bank-1 is running lean and the O2 sensor is working perfectly...
    So a combination of lawsuits, and political lobbying by the ASE, California has passed a law that prohibits facilities that do not have an actual repair shop from performing diagnostics.
    Autozone may allow you to borrow the code reader, but they may not legally connect it, operate it, or interpret the results.
  9. Jun 16, 2012 at 7:51 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Gotta love Commifornia. ;)
  10. Jun 16, 2012 at 7:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    This is one that I do not totally disagree with.
    A lot of people have spent a lot of money on parts they don't need because some high school kid read a code.
  11. Jun 16, 2012 at 7:55 PM
    goomba
    Josh
    San Antonio Fl
    ^^ He has a point here
  12. Jun 16, 2012 at 7:58 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Caveat emptor.
    The problem (not to get on a political rampage) is that because a few people got screwed (because they may have been dumb, duped, ignorant, mal-informed, mis-informed, clueless, retarded, a window-licker, whatever) it ends up screwing the masses over.
    Now, no one can have a code read?!
    To each his own. :)
  13. Jun 16, 2012 at 8:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Do you REALLY want your code read and interpreted by someone with absolutely zero training?
    Seriously... I don't like the DEALER working on my vehicles, and I certainly am not going to trust a minimum-wage auto parts store employee (I was one once) to plug anything into my OBD port.
    Nothing in the law prevents them from letting you borrow the scanner, and they WILL loan you a scanner and tools.
    The law just does not allow them to touch your vehicle or recommend a product based on a code. Being able to plug in a scanner does not qualify someone diagnose a problem.
    On touching a vehicle... a guy that I worked with at Trak Auto ended up buying a new windshield for a lady. He "helped" her install a new set of wiper blades. He let the wiper arm slip, and without a blade, it hit the glass and cracked it.
    Kid told the manager, who took care of it and the kid ended up paying the manager back. Corporate never knew... they didn't need to know.
    That's how it worked 30 years ago.
    Today, the kid wouldn't have admitted it to the manager.
    Likewise, today's manager wouldn't have fixed it... he'd have fired the kid and referred the customer to corporate... if she hadn't already called a lawyer.
  14. Jun 16, 2012 at 8:32 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    That should be okay then.
  15. Jun 16, 2012 at 8:47 PM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    i havent had any problems with it, it sounds and rides good, i plan on taking it to the dealership service department tomorrow. even though its expensive theyre going to find whats wrong and how to deal with it
  16. Jun 16, 2012 at 10:25 PM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Is it possible I failed because of my exhaust? I do have a magnaflow on
  17. Jun 17, 2012 at 6:31 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    No. A muffler is nothing more than baffles. The differences in mufflers are how they route and manipulate the flow of gas; it has nothing to do with a chemical alteration. Your catalytic converter may be failing, but your O2 sensor would throw up a CEL if something wasn't working properly.
  18. Jun 17, 2012 at 8:37 PM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    That actually might be it then, that sounds right looking at the fault codes it seems like it has to do with the gas flow. How do I go about fixing that?
  19. Jun 18, 2012 at 6:24 AM
    goomba
    Josh
    San Antonio Fl
