Brake light coming on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Holy schmidt, Sep 30, 2015.
  1. Sep 30, 2015 at 8:13 AM
    Holy schmidt
    Holy schmidt [OP] Well-Known Member
    Wyatt
    Nebraska
    My brake light comes on anytime I accelerate or turn but immediately goes off once I'm crusing in a straight line. Weird thing is not when I'm braking (that I've noticed). Also front and rear brakes have plenty of life and brake fluid is full. Pushing in the ebrake like some do doesn't turn it off. I'm sure it's something simple I just can't find it on here
  2. Sep 30, 2015 at 8:32 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    fill up your brake reservoir with fluid, even being just a 1/4" low or less then that will make the light come on
  3. Sep 30, 2015 at 8:52 AM
    Holy schmidt
    Wyatt
    Nebraska
    It's inbetween the min and max Does it need to be more towards the max?
  4. Sep 30, 2015 at 9:04 AM
    keakar
    karl
    louisiana
    yes, ignore the min line because your light will be coming on by then so always keep it right at the max line or just above. overfilling brake reservoir doesn't hurt anything, its just a cup that holds extra fluid for when and if the brake systems needs more.
  5. Sep 30, 2015 at 9:21 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    As your brake pads/shoes wear, the hydraulic system draws fluid from the reservoir. If you top it off, just be careful the next time you replace the pads/shoes. As you compress the pistons you could force the fluid out the top of the reservoir - and brake fluid will remove paint if not cleaned up immediately.
    Holy schmidt[OP] likes this.
  6. Sep 30, 2015 at 9:25 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  7. Sep 30, 2015 at 10:48 AM
    Holy schmidt
    Wyatt
    Nebraska
    Alright just topped off the fluid but headed off to class so I'll see if that's it hopefully on the way home! I am aware of the fluid rising as you compress the pistons
  8. Sep 30, 2015 at 4:47 PM
    Holy schmidt
    Wyatt
    Nebraska
    So after I added enough from inbetween min and max up to the max the lights not come back on. Thanks guys!
  9. Sep 30, 2015 at 6:47 PM
    keakar
    karl
    louisiana
  10. Sep 30, 2015 at 6:49 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    bell cranks frozen
