brake light help
Discussion in 'Lighting' started by yoterhunter, Oct 15, 2012.
  1. Oct 15, 2012 at 6:12 PM
    yoterhunter
    yoterhunter [OP] New Member
    i know i am a newbie but wondering if yall guys can help me.
    1998 toyota tacoma
    when i turn on my head lights the brake lights come on (they are bright and do not change when i tap the brake).. i mean the 3rd brake light is on, and the right and left brake light is on. I've tried tapping the brakes, checking brake fluid, and checked to make sure the parking brake was not on.
    any help would be great
  2. Oct 15, 2012 at 6:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Look for a ground wire that comes out of the rear taillights and grounds to the rear frame somewhere. Maybe :notsure:
  3. Oct 15, 2012 at 6:36 PM
    yoterhunter
    do that on all three of the lights?? i had a bumper built for the front and he changed out the blinker lights.. could that have had something to do with it?? this floors me
  4. Oct 15, 2012 at 6:39 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I would think they should ground somewhere but I'm no electrician (believe me) Look for cut or pinched wiring to the lights and body grounds.
  5. Oct 15, 2012 at 9:54 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The lower two brake lights are a dual element bulb. One element is dim, and used for the parking lights. The other is bright and comes on with the brakes. Sometimes the bulbs burn out in such a way that the two elements solder themselves together. This makes for all sorts of interesting problems, and I will bet that's what's going on with yours. Pull the bulbs and have a good, close look at those internal elements.
  6. Oct 15, 2012 at 9:55 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This is what I was thinking.
