brake light issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YNOT2K, May 23, 2012.
  1. May 23, 2012 at 5:28 PM
    YNOT2K
    YNOT2K [OP] Member
    Jeff
    Seattle, WA
    2005 Access TRD Offroad
    i have searched as long as i could stand with no success...
    i have a 2005 TRD 4WD OR with tow package.
    both of my brake lights are NOT lighting up when brake pedal is pressed. the third brake light on the cab DOES light when pedal is pressed.
    first i checked the fuse - it was good.
    then i checked the bulbs - both good.
    WTF???
    no other symptoms.
    any ideas?
  2. May 23, 2012 at 5:46 PM
    YNOT2K
    YNOT2K [OP] Member
    Jeff
    Seattle, WA
    i did not install new bulbs. they sure look good though. i can see that both filaments are still there and connected. hmmm. let me run to the store and get some bulbs and try that.
    seems strange both are out though?
  3. May 23, 2012 at 6:03 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) To start on a process to solve this problem, you need to buy a cheap test light. Go to Harbor freight and get a 3 or 4 buck test light and remove your bulbs, have someone push down on the brakes and make the lights work. Use your test light to see if it will light when inserted into the socket to check the terminals. If they light up, then your bulbs are bad. If the test light does not light up then we have a power problem. You also need to check for power to your trailer plug to see if will light up with the test light and the brake pedal depressed. If it does light up and the main sockets don't then you have a bad socket or a bad ground.
    You have some relays that control your brake lighting and your trailer lights. If you have VSC on your truck, then you have a relay that powers the brake lights though that relay. You also have a towing tail relay under the dash and you have #18 relay under the hood that controls trailer towing tail.
    This should give you homework to see if it helps. Good Luck.
  4. May 23, 2012 at 6:10 PM
    Skycam3
    Skycam3 Waiting to see...
    Tony
    Nashville
    2012 Tacoma DCLB TRD Sport 4x4
    Flyzeye, Redline hood struts, Demello Sliders, Pelly wrap around light bar, Roll-N-Lock tonneau cover, 2 Hella 700FF, DIY LED light bar(10,000 lumes), LED bed lights.
    Multimeter...you can check the bulbs, socket & wiring.
  5. May 23, 2012 at 6:10 PM
    YNOT2K
    YNOT2K [OP] Member
    Jeff
    Seattle, WA
    problem solved.
    new bulbs.
    i am an idiot - with brake lights that now work.
    that is all.
  6. May 23, 2012 at 7:09 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    Sometimes the issues that seem the hardest, have the most simple answer.
