Brake light issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JT., Feb 15, 2017.
  1. Feb 15, 2017 at 12:51 PM
    JT.
    JT. [OP] New Member
    07 blue Tacoma
    So I've got a 07 4wd access cab and I've been struggling with a brake light issues for several years now. Had the truck to the dealer several times and to a local mechanic with no solution.
    I'm the original owner and never had any serious issues.
    Problem- when I press the brake the 10amp fuse blows under the hood. Sometimes it will work for several weeks and other times it will blow every time I push the brake.
    Brake pedal switch has been replace and I've also disconnected the trailer light harness... nothing seems to help and I haven't found a common occurance when it happens.
    Any help would be greatly appreciated!!
    Next step might be a match....! Ha!!
  2. Feb 15, 2017 at 1:07 PM
    Pigpen
    Dan
    Northwest Montana
    It sounds like you have a short. There's probably a wire that moves around, causing the intermittent nature of the problem. Best of luck - it could be a real PITA to locate.
  3. Feb 15, 2017 at 1:11 PM
    JT.
    JT. [OP] New Member
    07 blue Tacoma
    Kinda what I was thinking...
    Seems like the longer I leave a fuse out the longer it will work when I install a new fuse.
    Thank you the reply!
