Brake light on after hitting brakes hard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike951, Feb 19, 2019.
  1. Feb 19, 2019 at 10:28 PM
    Mike951
    Mike951 [OP] Member
    Michael
    08’ 4x4 prerunner
    Long travel, intake, exhaust, engine cage, re-gear, etc....
    I have a 2nd gen and happened to slam on the brakes, moments after the brake light came on. I was confused on what to troubleshoot. Any advice?
  2. Feb 19, 2019 at 10:29 PM
    Bishop84
    Bishop84 Well-Known Member
    Brake fluid is low in the reseviour, likely brake pads are low. Check fluid, check your brakes.
  3. Feb 19, 2019 at 10:31 PM
    Mike951
    Mike951 [OP] Member
    Michael
    08’ 4x4 prerunner
    Fluid good, pads are good, thinking something electrical
  4. Feb 19, 2019 at 11:15 PM
    eon_blue
    Azusa, CA
    You mean the brake light came on for a second or it has stayed on? If it just came on for a second then it was probably the fluid sloshing in the reservoir and triggering the low level sensor, might need to top it off a bit.
    I have an 04 but I notice the brake light only comes on if I'm either slightly low on fluid or if the ebrake cable is too loose and needs tightening.
  5. Feb 20, 2019 at 1:51 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There are only three things that I know that turn on the "Brake" LED on the Combination Meter.
    1. Low Brake Fluid.
    2. Parking Brake Switch.
    3. Skid Control ECU.
    Scan for a code.
    Mike951[OP] likes this.
