Brake light on when truck is cold??
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Nov 30, 2011.
  1. Nov 30, 2011 at 7:14 AM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    The last two times I started my truck I noticed the brake light on the dash was on for no reason. In the past this light was only on if the parking brake was engaged. First time was after class and it was only for a few seconds before it flashed a couple times and stayed off. This morning though it was on for a good 20 minutes, then it started to come and fo, then finally stayed off. No smell of burning brakes and the truck rolled forward on flat ground in drive with no throttle applied so I'm guessing there are no brakes engaged but the dash seems to think so. Could this be related to my wiper fluid light staying on even though I filled it? (See other thread).
  2. Nov 30, 2011 at 7:16 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    The linkage sometimes gets stuck. Crawl under the truck, look on the left frame rail towards the back, but in front of the rear axle. You should see the parking brake cable go in to a pivot. Lubricate this pivot area. Should help.
  3. Nov 30, 2011 at 7:19 AM
    Hoyle
    Hoyle Well-Known Member
    Davidson, NC
    2014 DCSB 4x4 Black
    When you say "wiper" fluid do you mean brake fluid!
    My light came on recently and it was that the fluid was at minimum level. Filed to max and the light when out..
  4. Nov 30, 2011 at 7:23 AM
    rhewins13
    rhewins13 Well-Known Member
    Richard
    rhode island
    2013 sr5 debadged
    3" toytec lift, 20" chrome wheels with 295/55 r20 nitto trail grapplers, leer 100xr cap w/ thule bars
    Sounds like maybe your fluid is low. When it warms up, it expands so your light goes out. Try checking the fluid.
  5. Nov 30, 2011 at 7:30 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I'd bet on low fluid level. My truck has done it before,as well as my wifes Honda. Add just enough fluid to keep it at the full mark.
  6. Nov 30, 2011 at 7:31 AM
    JDMcQ
    who are you?
  7. Nov 30, 2011 at 7:33 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Where am I??:confused:
  8. Nov 30, 2011 at 7:46 AM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Make sure your brake pads and shoes are in good working order, ususlly when fluid level drops it's because everyday wear and tear have worn them down causing calipers and wheel cylinders to expand, caising fluid to drop in master cylinder which then makes your brake light to light up on your dask,,,,....check your brakes
  9. Nov 30, 2011 at 7:47 AM
    JDMcQ
    tree stand?
  10. Nov 30, 2011 at 7:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1 when the light comes on, and you have no leak, it's pretty close to "new brake pad" time.
    IIRC 2.5mm min on the fronts, 1mm min on the rears.
  11. Nov 30, 2011 at 8:13 AM
    x2468
    Vermont
    No I mean window wiper fluid
  12. Nov 30, 2011 at 8:15 AM
    x2468
    Vermont
    Alright ill check the brake fluid level. Ill be somewhat surprised if the pads are going since they feel do good when used. No sponginess or noises. But who knows ill check them. Plus ill grease that pivot.
  13. Nov 30, 2011 at 8:17 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Just a side note. The light went on in one of my cars and in my friends car when the third brake light bulb was not working....
  14. Nov 30, 2011 at 8:28 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    here shortly.:D
  15. Nov 30, 2011 at 8:28 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats a possiblity as well.
  16. Nov 30, 2011 at 8:46 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    As the pads wear, more brake fluid is added to the caliper to make up the space. You will not feel or hear anything related to this . You may hear the squealer on the pad riding on the rotor when it wears that low. Until then, it will be normal braking operation and sounds.
