Brake light problem
Discussion in 'New Members' started by TB's Tacoma, May 26, 2024.
  1. May 26, 2024 at 5:05 PM
    TB's Tacoma
    TB's Tacoma [OP] New Member
    2019 Toyota Tacoma
    New to Tacoma World.
    I have a 2019 Toyota Tacoma with a brake light issue. My left side brake light works perfect but cannot figure out why the right side does not work. Here are the things I have completed so far:
    1. Checked both the interior and under the hood fuses. Since left side is working, hard to figure they would be something wrong there.
    2. I pulled the brake switch and read continuity and of course it is fine.
    3. Changed the bulb with a new one and no joy. Took the working one from the left and tried it-no joy.
    4. Read power to the plug at the bulb and no power.
    5. I have looked the truck over for a corroded or loose grounding wire, but that is a no go.
    Is that something I am missing that you SME's could help me with? Is there a wiring connection midstream that I need to check? Can't understand why one side would work and the other does not.
    AMSK.505 likes this.
  2. May 26, 2024 at 6:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Has to be a broken/corroded wire between the splice and the right side connector.
  3. May 27, 2024 at 6:50 AM
    TB's Tacoma
    2019 Toyota Tacoma
    Thinking the same. I tested power to the trailer electrical outlet and I have power. That puts the problem right where you said. Thanks for the help. Hoping to solve this today.
    Dm93 likes this.
  4. May 27, 2024 at 7:50 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The trailer plug gets power from a separate source if you have the tow package.
    I wish Toyota gave the location of splices like they did on older stuff but they don't provide that info any more, at least not that I've been able to find.
    I wouldn't think it would be too far up the harness from the tail lights though.
  5. May 27, 2024 at 12:53 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  6. Aug 4, 2024 at 12:02 PM
    AMSK.505
    AMSK.505 Well-Known Member
    Albuquerque, NM
    2019 Tacoma TRD 4x4 OR DCSB - 2004 4Runner Limited V8 4x4
    Wondering if you were able to pinpoint the problem, I am having the same issue with my '19. Thanks!
